Wrknrvr Posted March 2, 2019 Report Share Posted March 2, 2019 This is a sign of water infiltration into the inside. if you see this you may want to try to remove the screw. Do it with a screw drive slowly. If you use a power device it may twist the head off. Now if the screw just rotates then the wood inside is probably aloft. Hopefully if you find a problem it is a small problem. Safe Travels,. Vern Link to comment Share on other sites More sharing options...
Kirk W Posted March 2, 2019 Report Share Posted March 2, 2019 A very good point! Something that every RV owner should be watching for. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
