DesertMiner Posted October 4, 2018 Report Share Posted October 4, 2018 Chemical cleaners are not designed to stop the injectors from leaking. Usually if you have a leaking injector it needs to be replaced. Link to comment Share on other sites More sharing options...
Quickthrotl Posted October 4, 2018 Report Share Posted October 4, 2018 Does the truck stay running after you start it or will it die after awhile, when it dies or you shut it off do you hear bubbling in the fuel tanks? 2004 Volvo VNL 780 2017 Momentum 376TH 2007 Harley Davidson FLHTC 2009 Smart4two Link to comment Share on other sites More sharing options...
Cotreker Posted October 4, 2018 Author Report Share Posted October 4, 2018 Truck runs, hard starting. I will have to listen for bubbling in fuel tank. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Cotreker Posted November 5, 2018 Author Report Share Posted November 5, 2018 On 9/30/2018 at 6:59 PM, Alie&Jim's Carrilite said: Your system is losing prime. Now the hard part begins. What connection or check valve or injector is remaining open (partially)? Jim, I fully agree my truck is losing prime. I hit the primer pump again today and again noticed fuel and air coming up just to the right of the pump handle, this is a small hex cap that was about 1/2 turn loose. It now pumps up fast and the pump is solid. Since the truck once again got air into the system it took 3 attempts to get a start. I will wait 48 hours and then attempt a start. If not I will keep looking......... Since I am spending much more time in the engine compartment I came across a 1/4" air line with a small leak, . Re-cutting the line did not fix this issue. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
