jpcoll01 Posted May 19, 2018 Report Share Posted May 19, 2018 Looking for inventive ways to store the exterior unit and mount the interior unit. I want to ditch my roof air. Link to comment Share on other sites More sharing options...
jcussen Posted May 19, 2018 Report Share Posted May 19, 2018 motorhome, 5th wheel, travel trailer? Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
jpcoll01 Posted May 19, 2018 Author Report Share Posted May 19, 2018 Motor home. Class C 30ft Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 19, 2018 Report Share Posted May 19, 2018 There are several that have mini splits in traditional RV's. Glen West is one of them. There is also a SpaceCraft RV, Gail, and Steve Dixon, that was designed with mini splits for heat and AC. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
jcussen Posted May 19, 2018 Report Share Posted May 19, 2018 Evaporator could be placed anywhere you want inside motorhome but condenser/compressor portion will need a compartment location that allows good air flow over condenser. Best to measure your biggest compartment and get dimensions of the mini-split outside portion and go from there. A lot of older bigger motorhomes have "basement air" but their compartments are pretty big. You will find many of the modern bigger motorhomes have gone back to roof airs. [Newell and many Prevost conversion bus's] Think it would be a lot easier on a 5th wheel than a 30ft class c. Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
GlennWest Posted May 20, 2018 Report Share Posted May 20, 2018 I built a frame at rear of my Teton 5th wheel for the exterior unit. Can you do that? Steve and Gail's is on storage area but storage was designed orinally into build. You will need 2 heads inside. Plenty of room inside for this on ours. On a mh, I'd place one at each end. Can you use 240v? If so, 1 outside unit is all you need. 2 if 120V. Steve and Gail's interior units run in a duct sorta. A cover in center of celling, routing air. Unsure which evaporator unit they using. One is sold to mount in a duct and suspect that is it. If center of ceiling open, this is neat effective way. They have a video of their unit that Greg Shields made. It shows them. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
