Shallow Draft Posted November 2, 2017 Report Share Posted November 2, 2017 Well we are back in Maricopa for the winter season. The heat feels great. Not the usual uneventful trip I like to have. I left home with a cold and took a cold remedy [Cold FX] that did not agree with me and my blood pressure dropped to the point of passing out at the wheel. SO My wife had to drive the first day. She had not driven the Volvo with 38 ft of horse trailer. She did fine but it shows the importance of having a co-driver. Next was Las Vegas. I missed Vegas Teachers exit and ended up in a bumper to bumper 5 mile parking lot until I could get to the 215 exit. Now the fun part!! At 5PM the inside dual is flat 30 miles SE of Boulder city. Minimal to no cell service. I could not contact Good Sam but got one call to Us Rider road side assistance. They were sending a tire truck ASAP but 3 hours later no show. I was able to Text so I had a friend relay the location and clearly stated need of a tire service truck. They sent a massive tow truck that was not needed or of any use. The good part is the driver new who to call and his cell phone worked and a tire truck was on the way. He got here at 1:30 and I was good to go by 4:00 am. The valve extension I had on for my tire pressure monitor broke the tip off the vale stem. After a fight with US Rider on what they would cover I paid the $520.79. I am trying to get some of that back now. Lessons Learned on this trip: 1. Make sure your co-driver can take over. 2. Be prepared for traffic challenges. 3. Have a cheater wrench to get the lug nuts off 4. Do not have valves stem extensions on the inside dual wheel. Other than the above the trip was great. The Volvo purred the whole way and had no other issues. Link to comment Share on other sites More sharing options...
Jack Mayer Posted November 2, 2017 Report Share Posted November 2, 2017 Valve extensions are fine as long as they are minimum length required and solid steel - not flex line. At least that is my opinion. I happen to like Crossfire on the rears, but others don't find that necessary. Link to comment Share on other sites More sharing options...
NeverEasy Posted November 2, 2017 Report Share Posted November 2, 2017 Validated Members 196 posts Report post Posted just now Cheater wrench, 1:65 ratio. Takes truck lug nuts off with ease. Funny looking extension in the lid is so once you break the nuts loose you connect this direct drive to the handle. https://www.amazon.com/Torque-Multiplier-Lug-Nut-Wrench/dp/B00FPS5SQS/ref=sr_1_3?ie=UTF8&qid=1509660911&sr=8-3&keywords=lug+wrench+torque+multiplier&dpID=51CcAHde4pL&preST=_SY300_QL70_&dpSrc=srch Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 2, 2017 Report Share Posted November 2, 2017 21 minutes ago, NeverEasy said: Validated Members 196 posts Report post Posted just now Cheater wrench, 1:65 ratio. Takes truck lug nuts off with ease. Funny looking extension in the lid is so once you break the nuts loose you connect this direct drive to the handle. https://www.amazon.com/Torque-Multiplier-Lug-Nut-Wrench/dp/B00FPS5SQS/ref=sr_1_3?ie=UTF8&qid=1509660911&sr=8-3&keywords=lug+wrench+torque+multiplier&dpID=51CcAHde4pL&preST=_SY300_QL70_&dpSrc=srch Chet, These work but take a lot of turns to get nut off, so be prepared to give your arms a workout.😀 Link to comment Share on other sites More sharing options...
NeverEasy Posted November 2, 2017 Report Share Posted November 2, 2017 Carl, That is why I carry one of these with a 1/2" to 1" adapter. I used to carry a air impact but this does the job. Just a couple of turns with the torque-multiplier and an impact will do the rest. https://www.amazon.com/Milwaukee-2764-22/dp/B00GFTS19C/ref=sr_1_15?ie=UTF8&qid=1509662712&sr=8-15&keywords=milwaukee+m12+impact+wrench Added together, the wrenches are a bit pricey but waiting 8 hours for service and a $500 bill makes the price reasonable. Could have easily run in on one tire of the duals. Link to comment Share on other sites More sharing options...
Shallow Draft Posted November 3, 2017 Author Report Share Posted November 3, 2017 13 hours ago, Jack Mayer said: Valve extensions are fine as long as they are minimum length required and solid steel - not flex line. At least that is my opinion. I happen to like Crossfire on the rears, but others don't find that necessary. Jack I had the other side fail the same way last year, it only created a slow leak and I was able to fix it on my own time for $30.00. After the second one failed at the same point but with out the benefit of a slow leak I am a little more concerned. Maybe it was just bad luck. Link to comment Share on other sites More sharing options...
Jack Mayer Posted November 3, 2017 Report Share Posted November 3, 2017 3 hours ago, Shallow Draft said: Jack I had the other side fail the same way last year, it only created a slow leak and I was able to fix it on my own time for $30.00. After the second one failed at the same point but with out the benefit of a slow leak I am a little more concerned. Maybe it was just bad luck. That is a bummer. I've had the flex lines fail if not supported. But I've never had a long valve line that was solid fail. I've had the rubber seal leak if the nut was not tight, though. Link to comment Share on other sites More sharing options...
