alan0043 Posted May 14, 2017 Report Share Posted May 14, 2017 Hi Everyone, I crawled under the front of my truck looking for a drain at the bottom of the radiator. I had no luck. I also looked for shut off valves that go to the heater cores, with no luck. It is so hard not to believe there is no drain at the bottom of the radiator. I need to lower the level of the engine coolant so I can get out the heater core in the sleeper. I don't want to loosen and remove a hose to lower the level of the coolant. All that does is make a big mess. If I were changing out the coolant. That way would not be a big a big problem. Does anyone have an idea to help lower the coolant level ? I want to save and re-use the coolant over. Open for ideas, Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
MrSeas Posted May 14, 2017 Report Share Posted May 14, 2017 You need to use "Volvo's adapter" There is a fitting near the bottom on the radiator usually on the passenger side. Looks like a "quick disconnect type fitting". Here is an example of the Volvo adapter.... https://otrperformance.com/product/volvo-radiator-coolant-drain-hose-9996049/ Link to comment Share on other sites More sharing options...
alan0043 Posted May 14, 2017 Author Report Share Posted May 14, 2017 52 minutes ago, MrSeas said: You need to use "Volvo's adapter" There is a fitting near the bottom on the radiator usually on the passenger side. Looks like a "quick disconnect type fitting". Here is an example of the Volvo adapter.... https://otrperformance.com/product/volvo-radiator-coolant-drain-hose-9996049/ Hi MrSeas, Thank you for posting the link. I will need to crawl under the truck again and see if I can find a fitting like they show in the video. Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 14, 2017 Report Share Posted May 14, 2017 1 hour ago, MrSeas said: You need to use "Volvo's adapter" There is a fitting near the bottom on the radiator usually on the passenger side. Looks like a "quick disconnect type fitting". Here is an example of the Volvo adapter.... https://otrperformance.com/product/volvo-radiator-coolant-drain-hose-9996049/ You are a wealth of information. Is that connection an odd size or proprietary to Volvo or could that same tool be made up cheaper than $60? 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
MrSeas Posted May 14, 2017 Report Share Posted May 14, 2017 Not sure on the size... I have seen the fitting at a better price. I'll see if I can find the part #. Link to comment Share on other sites More sharing options...
alan0043 Posted May 15, 2017 Author Report Share Posted May 15, 2017 17 hours ago, MrSeas said: Not sure on the size... I have seen the fitting at a better price. I'll see if I can find the part #. Hi MrSears, That would be great for a part number. I thought the same thing on the cost. Seems to be on the high side. $30 would be a fair price. Carl, I think the part is just for Volvo trucks. The part that is attached to the radiator looks like a male quick connect for an air line. But there must be something special about this part. The end is open and no liquid come out unless you use the hose with the adaptor. Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
alan0043 Posted May 15, 2017 Author Report Share Posted May 15, 2017 23 minutes ago, alan0043 said: Hi MrSears, That would be great for a part number. I thought the same thing on the cost. Seems to be on the high side. $30 would be a fair price. Carl, I think the part is just for Volvo trucks. The part that is attached to the radiator looks like a male quick connect for an air line. But there must be something special about this part. The end is open and no liquid come out unless you use the hose with the adaptor. Al It also looks like Mack trucks use's this style of hose to drain their radiator. I wonder if the Mack truck part number might be cheaper. I have not find the Mack truck part number yet. Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
