Air Spring/bag replacement
trimster
On my 1998 international 4700 sport chassis both air bags are ready to die. I'd like to put lighter duty ones there in hopes of a softer ride. So, questions: which ones (model number)? and how about the Double Convoluted Air Spring designs? any advantage or disadvantage to those as a replacement for the stock bags? I typically see critical measurements listed like deflated and inflated height, bolt placements but rarely the weight rating. I think, not sure, that stock is like 12k lbs. Might be way off.
Thanks
Bob
Robert & Lisa
'14 Keystone Fuzion 315 38' 5er
2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours)
2013 Smart Fortwo Passion 'K-9'
2011 CanAm Spyder RT Limited (Ours)
We are both USAF vets.
Big truck bags don't work on pressure, they work on volume. If the pressure is lowered it lowers the frame closer to the differential, changing the angle of the universal joint. May turn out bad. I think a bag with larger diameter, more volume, would soften the ride.
Ron C.
2013 Dynamax Trilogy 3850 D3
Noteven: I got in touch with them and they were helpful but could not help. I asked for a replacement bag rated for a lower load. They can only quote factory equivalents listed for the truck. I'm going to try the parts guy at the local International dealer.
Ronbo: Hmmm. Does not seem logical but some things about these trucks baffle me. Just talking out loud here, it would seem that if I find the point where the bag is inflated to proper height but not to rated 'full' pressure, it would ride softer and keep the frame off the tires (loPro chassis configuration).  Am I off target here?
Bob
Robert & Lisa
Yes you can set the ride height at a lower pressure. You would have to install a regulator on the feed line to the valve. As far as the Navistar dealer giving you another part number I don't think that will ever happen. All "big trucks" are built to spec that is why when you need parts for it we need your vin number, Every truck can be different, all depends on what the customer wants.
If your truck has a hard ride chances are the air pressure is to high in the bags and could be due to the rear suspension spec. If you want to give me the last 8 of your vin number I can look it up and let you know how it's built.
Rick
Sorry this does not lay out here well but you should be able to see it.
Any questions let me know
If you look below down by 13 the truck has a 15,500 lb rear axle and look by 03 and you will see the air suspension is rated for 17,500 lbs.
Line Set Ticket
VIN Number 1HTSLAAK7VH482547 Model 4700 LO-PRO4X2 Build Date 1/31/1997
Eng Srl Number 001032185 Model Code SH47540 Order Qty 2
Dealer Number 676601 Order Number/Suffix 277649B Starting Job Number 482547
Sold To ELLIS AND CAPP EQUIPME Sales Region   Paint Code 9219
GVWR 18280 Ignition Key K483 Wheel Base 188.0  in / 477.5 cm
AF Dimension 75.0  in / 190.5 cm Gear Ratio 3.91 Recall Pending No
Grp Unit   Div Variation SE Description Cost Code
01 0001951 Unit Code Search 2007   SE FRAME PRCNG S-SERIES Yes
01 0001AHK Unit Code Search 2001 CDGH   FRAME 9.125X3.062X.312 (80,000 PSI)
01 0001LLT Unit Code Search 2000 BE   BUMPER-FULL WIDTH-CHROME PLTD ALUM-AERO
02 0002ADA Unit Code Search 2001 C   INTERNATIONAL I-60S 6,000# FRONT AXLE
03 0003SAM Unit Code Search 2016 ACZ   INTL 17500# AIR SUSPENSION
04 0004040 Unit Code Search 2090 ACLW SE BOSCH HYDRO-MAX II SPLIT BRAKE SYSTEM
04 0004144 Unit Code Search 2004     15X1.435 FRT DISC HYDRAULIC BRAKE
04 0004237 Unit Code Search 2002     15X1.435 REAR DISC HYDRAULIC BRAKES
04 0004GAB Unit Code Search 2003 D   12X4 DCM PARKING BRAKE
04 0004RBE Unit Code Search 2017 ACEM SE 13.2 CFM AIR COMPRESSOR-BENDIX-550
05 0005710 Unit Code Search 2042 AFK SE STEERING COLUMN W/TILTING & TELESCOPING
05 0005PRG Unit Code Search 2115 DFJVW   TAS-40 ROSS POWER STEERING
06 0006721 Unit Code Search 2193     ONE PROP CTR BRG BRKT
07 0007AAY Unit Code Search 2098 FG   SGL EXH SYS(HORZ MFLR/TP)-SHORT TP(RSM)
08 0008000 Unit Code Search 0110 BCGHJLQSUZ   ELECTRICAL SYSTEM (12 VOLT)
08 0008518 Unit Code Search 2007     CIGAR LIGHTER
08 0008544 Unit Code Search 2010 B   DUAL AIR HORNS (GROVER) CHROME
08 0008585 Unit Code Search 2011 AB   TOGGLE SW/WIRING-CUSTMR MTD DR/FOG LGHT
08 0008GBN Unit Code Search 2013 B   12V 90AMP DELCO CS-130 ALTERNATOR
08 0008MED Unit Code Search 2068 AF SE BATTERY(2-FLTRITE)MAINT-FREE 12V 1100CC
08 0008RAK Unit Code Search 2010     CB RADIO ACCOM PACKAGE
08 0008RAU Unit Code Search 2006 ADF   ELEC TUNED AM/FM/CASS/CLOCK RADIO
08 0008RBK Unit Code Search 2003     DUAL CB ANTENNAS
08 0008WAU Unit Code Search 2001 AF   WINDSHIELD WIPER SWITCH (INTERMITTENT)
08 0008WCB Unit Code Search 2003     WARNING LIGHT/BUZZER-ENG OIL PR/WTR TEM
08 0008WCG Unit Code Search 2000     RADIO NOISE SUPPRESSION FILTER Yes
08 0008WML Unit Code Search 2000     HEADLIGHTS (2) LONG LIFE HALOGEN Yes
09 0009107 Unit Code Search 2177 BDFMSUX   HOOD ASM, TILT
10 0010000 Unit Code Search 2002 BT   SPEEDO & MISC
10 0010210 Unit Code Search 2000     EMISSION LABEL (FUEL ECONOMY / NOISE)
10 0010761 Unit Code Search 2000     PAINT BASE COAT/CLEAR COAT 1-2 TONE Yes
10 0040010 Unit Code Search 0001     MEDIUM DUTY STD WARRANTY Yes
11 0011001 Unit Code Search 2000     OMIT CLUTCH & CONTROLS Yes
12 0012959 Unit Code Search 2007     ENG BLOCK HEATER (PHILLIPS)120V-1250W
12 0012NHD Unit Code Search 2061 BELMNVX   DT 466E HEUI INT DSL 230HP/2300RPM
12 0012TSJ Unit Code Search 2016 A   FAN DRIVE(SCHWITZER DD-30)VISCOUS
12 0012UGM Unit Code Search 2001     ELECTRONIC ROAD SPEED GOVERNOR Yes
12 0012UGN Unit Code Search 2006 BD   THROTTLE CONTROL ELECTRONIC
12 0012USC Unit Code Search 2026 BDFGL   381 SQIN RADIATOR & 304 SQIN AIR COOLER
12 0012VVN Unit Code Search 2006     ELECTRONIC CRUISE CONTROL Yes
13 0013ABB Unit Code Search 2105 ADFNQUWZ SE MD-3060/CR ALLISON 5-SPD AUTOMATIC TRAN
13 0013WBL Unit Code Search 2000     ALLISON PUSH-BUTTON SHIFT CONTROL Yes
13 0013WTA Unit Code Search 2000     ALLISON SPARE INPUT/OUTPUT Yes
14 0014ADP Unit Code Search 2014 DTV   INTERNATIONAL S150S 15500# REAR AXLE
15 0015SAC Unit Code Search 2106 CEGJ   SGL 50G FL TK W/STEP(RSM)(STL-RECT)U/CA
16 0016000 Unit Code Search 2373 BFHPT   TRANS COVER, FLOOR MATS, SEALS
16 0016196 Unit Code Search 2076 ADFHNS   CREW CAB
16 0016400 Unit Code Search 2001     OMIT PASSENGER SEAT Yes
16 0016660 Unit Code Search 2000     TINTED GLASS, ALL WINDOWS Yes
16 0016CCB Unit Code Search 2000     COLOR - PEARL GRAY Yes
16 0016GAU Unit Code Search 2000   SE DUAL RETRACTABLE MIRRORS
16 0016HAB Unit Code Search 2003 A   ENGLISH GA CLUSTER W/ENGLISH SPEEDO/TAC
16 0016JAD Unit Code Search 2001 BCN   FRONT BENCH SEAT VINYL W/VINYL
16 0016PZR Unit Code Search 2000 BC   REAR BENCH SEAT - VINYL W/VINYL
16 0016WAK Unit Code Search 2002     POWER WINDOWS (LT&RT DOORS) Yes
16 0016WKB Unit Code Search 2152 AEGNRS   HTR&A/C (INTERNATIONAL BLEND-AIR)
16 0016WMJ Unit Code Search 2001   SE DUAL CONVEX SS 8" MIRRORS
16 0016WSD Unit Code Search 2004 CEKMQSTW   INTERIOR TRIM PREMIUM - CREW CAB
16 0016ZAA Unit Code Search 2015 A SE CAB ACCESS PKG (DRIVER/PASS SIDES)
17 0027DNA Unit Code Search 2000 AD   DISC FRT WHLS(19.5"PT-STL 8S)6.75DC RIMS
17 0028DNA Unit Code Search 2000 AB   DISC RR WHL(19.5"PT-STL 8S) 6.75DC RIM
17 0029580 Unit Code Search 2000     INTERNATIONAL WHEEL SEALS (FRONT) Yes
Top Explanation of Prop Shaft Locations
259DTA1402 *PROP SHAFT 1
259DTL1590 PROP SHAFT 1
UNISTEEL G133
AOTNMT01 TBLS N/M MT ASM 6
7309020179 *8R19.5-12PR 6
Prop Shaft Information
Great info. Thanks. Seems the truck was delivered to the builder who outfitted it as a toter. It was gray but was repainted white. Interesting.
That's some fairly heavy bags. Hmmm. Need to find lighter weight/load ones.
Bob
Robert & Lisa
That is how all trucks leave the factory. Cab and chassis except in some cases a school bus will leave complete.
Think of the air bags as a basketball. The more air pressure in it the harder it will bounce.
Think about it your rear axle is made for 15,000 and your putting 1,500 to 3,000 pounds on it. I don't know your pin weight but it's nothing compared to want it's made for.
If you had a bounce to your ride I would say you need shocks  if it's stiff the bags are too tight. You have to adjust because you have no weight to speak of on the truck
