Frigidaire FFTR1322 starting/running loads
RV fan
I don't have the specs, but Id venture a pure guess whatever current they "publish" is running NOT short term starting surge amps. Also, if ????? it did indeed draw 6 running amps at 120 volts, that alone is 720 watts and when you figure an inverter also has to have enough momentary surge capacity to START the compressor (may be 4 to 6 times running current) A 600 WATT INVERTER WONT DO THE JOB.
If you knew the actual starting surge and running amps then you can predict whether or not an x watt inverter will work.
FWIW my small dorm size Haier fridge draws 1 to 2 amps and its tiny, so a larger fridge (subject to size) might draw 6 amps BUT I JUST DONT KNOW WHAT YOURS ACTUALLY DRAWS
Best I can do absent any hard specs. If anyone finds the actual amps, then I can provide better advice
John T
RV Fan, if these links and manuals are correct for your FFTR1222 (NO idea, NO Warranty)
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=FFTR1222&User=&Search=Search
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/242301700.pdf
IT ONLY DRAWS 0.8 to 1.5 amps (180 watts at 1.5 amps)
THEREFORE if that's correct (no warranty) your 600 Watt PSW Inverter "should" work iffffffffffffffff it has sufficient surge capacity and you have big enough wires from it to batteries and all else is correct and sufficient.
Best I can do
John T
Buy a Kill-A-Watt and measure it yourself, they are under $20 at Amazon - http://www.amazon.com/P3-P4400-Electricity-Usage-Monitor/dp/B00009MDBU/. An alternative, which I own, is the TS-836A for $16 - https://www.amazon.com/TS-836A-Energy-Voltage-Electricity-Monitor/dp/B00E945SJG/. You will find one of these useful for more than just finding out how much power the fridge uses.
@John T,
Thank you, that is the tech data sheet I was looking for. That range is approx what I think I saw posted somewhere in the past. I will still call the mfr tomorrow to see what they say. The inverter I am looking at has a 1200 watt surge capacity. If the 6A draw (720W) posted in the generic specs for the refer then I should be OK. Refer is due in late next week or possibly as late as 10/27/16. I'll keep this thread posted.
Thank you,
@Bill J.
Thank you for your response. I think I will invest in one of those, I can see the value in one.
@jcussen,
Thank you for the info. I'm hoping this refer has efficient motor controls to slowly ramp up/down the power, along with an efficient motor/compressor.
