RV_ Posted October 5, 2016 Report Share Posted October 5, 2016 If the Windows 10 cumulative update to 1607 (Anniversary update) update over the weekend refused to complete installing, then reverts, then repeats, here is a fix and more information. Excerpt: "The latest cumulative update to Windows 10, KB3194496, is causing frustration for some PC owners, with the update trying and failing repeatedly to install. I've learned who's most likely to be affected and also have two recovery options. The problem occurs with Cumulative Update KB3194496, which was released for Windows 10 version 1607 on September 29, 2016. For most users running the latest public release of Windows (version 1607, also known as the Anniversary Update), this cumulative update completes successfully and brings the current build number to 14393.222. But if you're one of the unlucky ones affected by this bug, after the required restart the system reaches the "100 percent complete" mark and then announces: "We couldn't complete the updates. Undoing changes." The whole process only takes a few minutes but it's annoying. It's also frustrating, because the update will try again the next day, only to fail again. Fortunately, the issue appears to be limited to a relatively small subset of Windows 10 devices. You are at greatest risk if you have a machine that was previously part of the Windows Insider Program but was then removed from the program. The most likely time for this to happen was in late July or early August, after the release of the Anniversary Update. And indeed, I encountered the failed update on two systems that matched that description to a T. Both had been part of the Windows Insider Program but were removed when the Release Preview build arrived and are now running the public (Current Branch) release, build 14393." While it involves deleting some folders and making two changes to the registry. Find all the details and instructions in the whole article here: http://www.zdnet.com/article/why-windows-10-cumulative-update-kb3194496-is-failing-and-how-you-can-recover/? ftag=TREc64629f&bhid=19724681974700635514865380622813 RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
Al F Posted October 5, 2016 Report Share Posted October 5, 2016 Thanks for the tip. I see from the referenced article that Microsoft is working on a fix. I made sure our 2 laptops have the "download over metered connection" turned off so automatic downloads won't come in. Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
RV_ Posted October 5, 2016 Author Report Share Posted October 5, 2016 No Prob Al. RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
mrschwarz Posted October 6, 2016 Report Share Posted October 6, 2016 I had the problem on one of mine and followed the instructions to fix it. It worked and it wasn't all that difficult. Michael 2017 Allegro Bus 45OPP Cummins ISL 450 Visit us at schwarz.org! Link to comment Share on other sites More sharing options...
RV_ Posted October 6, 2016 Author Report Share Posted October 6, 2016 MIchael, Thanks for the feedback. Lots of folks freeze up when a registry edit is mentioned, but this one is easy to follow. RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
