Exile Posted September 17, 2016 Report Share Posted September 17, 2016 I looked at a 2009 yesterday, and when it was idling, i noticed a whooshing noise on the passenger side when walking around the truck while it was idling. Not quite a whistling noise. Is this the case for all dpf trucks? I am used to driving old junk before the 7th injector was used. Does this bode ill for the longevity of the filter? 450k or so on the clock, 15k hours. Link to comment Share on other sites More sharing options...
Nigel Posted September 17, 2016 Report Share Posted September 17, 2016 If it was a Volvo it could also be the exhaust brake coming on to help warm up the truck. Mine quite often does that when the engine is cold. Kind of like a potato in the tailpipe noise. Nigel Link to comment Share on other sites More sharing options...
jeffw Posted September 17, 2016 Report Share Posted September 17, 2016 Mine makes a similar noise as it's warming up. If you want to test for sure, shut off the truck and bleed out all the air using the foot brake pedal. Restart the truck and once the air pressure comes back up to around 80 psi you'll hear the exhaust brake come on (it's air activated). it'll come on at the same time the fan clutch turns off (it's also run from air). You should hear the noise start once the the exhaust brake engages. Link to comment Share on other sites More sharing options...
MrSeas Posted September 17, 2016 Report Share Posted September 17, 2016 found this.....It's for 2011 and later Volvo trucks. I bet its similar for the 2008-2010 model years also with DPF. http://www.volvotrucks.us/~/media/vtna/files/shared/parts%20and%20services/service_at_a_glance_poster.ashx?as= Link to comment Share on other sites More sharing options...
Exile Posted September 18, 2016 Author Report Share Posted September 18, 2016 Thanks, those are good answers. It was a Mack, so I understand that to be the same engine. Mostly. I actually heard the engine take load right after starting, so i bet that was the exhaust brake, Jeffw. And thats a great chart for maintenance schedules, MrSeas. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted September 18, 2016 Report Share Posted September 18, 2016 Interesting oil change intervals. Doubt many of us wait that long, lol. Link to comment Share on other sites More sharing options...
hone eagle Posted September 18, 2016 Report Share Posted September 18, 2016 I follow the factory oil change interval - from the manual, mine stops after 7 mpg so I use that - 40,000 km Link to comment Share on other sites More sharing options...
