Bob Vaughn Posted August 26, 2016 Report Share Posted August 26, 2016 Our dog which is house broke took a pee on our carpet in the 5th wheel. Stanley Steamer could not get the stain out so we have a dark stain on our carpet. I am looking for a solution to this problem. Replacing the carpet right now is not an option. I wonder if a carpet dyer could just dye the carpet?? Link to comment Share on other sites More sharing options...
Bobi and Dick McKee Posted August 26, 2016 Report Share Posted August 26, 2016 You might try some of the dog stain removal sprays sold at places like Pets Mart etc. Link to comment Share on other sites More sharing options...
remoandiris Posted August 26, 2016 Report Share Posted August 26, 2016 Google is your friend. Lots of options; https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=dog%20urine%20stain%20on%20carpet Link to comment Share on other sites More sharing options...
Bob Vaughn Posted August 26, 2016 Author Report Share Posted August 26, 2016 I have that one but on a different site a lot of users said it takes the smell out just not the stain. I am going to try it any way. I cannot ruin the carpet the dog already did that..... Link to comment Share on other sites More sharing options...
Bobi and Dick McKee Posted August 26, 2016 Report Share Posted August 26, 2016 Our cleaner told us that the stain usually goes into the pad. He poured a quart of water over the stain and then used a wet dry vac to pull up the water. It was amazing how much urine came up in the vacuum. Link to comment Share on other sites More sharing options...
Randyretired Posted August 26, 2016 Report Share Posted August 26, 2016 I have found that using detergent on a pee stain will set the stain. Instead I use lots of water and pick it up. Then finish with vinagar and water about 50-50. To get it out now you might try oxiclean but if left on to long or to strong it may bleach the spot. Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
Mr. Camper Posted August 26, 2016 Report Share Posted August 26, 2016 Try a mixture of oxy-clean with hot water. Pour it on the stain and then blot it out with a towel. Worked fine for us. GOOD LUCK. Link to comment Share on other sites More sharing options...
mkc Posted August 27, 2016 Report Share Posted August 27, 2016 We have had good luck with Capture, which is an enzymatic spray/powder (likely diatomaceous earth) combination product. It is available at Home Depot last I checked. You mist the stain with the spray, work the powder in with a brush and let it dry for several hours, then vacuum. This is a similar product to one marketed as pet-specific, www.planeturine.com if you need larger quantities. Now, if the stain is a lightening/bleaching of the carpet, this unfortunately won't help. Michelle Link to comment Share on other sites More sharing options...
WeBeFulltimers Posted August 27, 2016 Report Share Posted August 27, 2016 I would get the smell out and cover the stain with a rug if I couldn't replace the carpet for now. Fulltiming since September 1, 2010 2012 Ford F-350 PSD SRW Lariat Crew Cab 2012 Montana 3585SA Link to comment Share on other sites More sharing options...
