hummingbird Posted July 25, 2016 Report Share Posted July 25, 2016 hi folks me again the newbie we had a clog of toilet paper in our toilet, took us about two hours to pull the crap out. to do so we had to shut off the water and hold open the toilet flapper (or whatever its called) to reach down and pull the paper clogging the drain hole. now when we use the pedal flusher lever it sticks open, after many time of pushing the lever up and down it will final shut. Any suggestions to help that lever mechanism work properly again? Incase your wondering; we have been using the proper toilet paper but I don't think we were allowing enough water to go through to carry the paper through the drain pipe. We are using the proper amount of water now and have had no problems with clogs. Thanks Link to comment Share on other sites More sharing options...
Orvil Hazelton Posted July 25, 2016 Report Share Posted July 25, 2016 I believe that you've gotten the flapper out of adjustment. A slight movement of it while it is in the closed position is required. This may need to be repeated a couple of times to get it right. Be sure to clean any deposits from it as well. I've had to perform the same ritual several times over the years. A better design is needed. As always, oRV oRV 75065 Lifetime Member 2010 Phaeton 40 QTH 2014 Honda CR-V Toad Link to comment Share on other sites More sharing options...
sandsys Posted July 25, 2016 Report Share Posted July 25, 2016 If you pour some vinegar into the toilet and let it sit a few minutes it will dissolve any mineral deposits that may be interfering with the flapper working. When we were going to be away for any length of time we poured mineral oil into the bowl to keep it lubricated--water evaporates; mineral oil does not. The oil also offers a little lubrication to the dump mechanism--not much because it gets diluted by all the water in the tank but a little. Linda Sand Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Chris-n-Dennis Posted July 25, 2016 Report Share Posted July 25, 2016 What oRV and Linda said - and actually rub some of that mineral oil on the rubber gasket. You clean and lube with one motion. Berkshire XL 40QL Camphosting and touring Our blog: cndtravels.blogspot.com Link to comment Share on other sites More sharing options...
bruce t Posted July 25, 2016 Report Share Posted July 25, 2016 I've use WD40 or CRC a few times. Seemed to work fine. regards Link to comment Share on other sites More sharing options...
