wzahnd Posted February 19, 2016 Report Share Posted February 19, 2016 I have a 2955 montana and recently noticed the bed when moved on the slider in and out is tearing the carpet, the wood framing is riding on the carpet and the is zero clearance between the bed's wood siding and the roller under one corner. Any suggestions how to approach repair without a lot of unnecessary invasive exposure. Thanks. Wally 1995 Dodge Dually, 2001 Montana 5th wheel. Link to comment Share on other sites More sharing options...
jjwicklund Posted February 20, 2016 Report Share Posted February 20, 2016 I have a 2955 montana and recently noticed the bed when moved on the slider in and out is tearing the carpet, the wood framing is riding on the carpet and the is zero clearance between the bed's wood siding and the roller under one corner. Any suggestions how to approach repair without a lot of unnecessary invasive exposure. Thanks. Wally 1995 Dodge Dually, 2001 Montana 5th wheel. Do you have bars of gold stored in the under bed storage? John 2017 F350 King Ranch DRW 6.7 4.10 B&W hitch 2017 DRV MS 36RSSB3 Link to comment Share on other sites More sharing options...
rdickinson Posted February 20, 2016 Report Share Posted February 20, 2016 See if you can post some pics of the inside of the bed frame box with the mattress tipped up. It may pivot on the pillow end, lifting up from the foot end. In my case there are rollers at the foot end of the bed rolling on the floor. You may be able to lift the bedframe up a bit and loosen then drop the rollers so the roll on the carpet but the frame itself doesn't contact the carpet. If you are not able to post on the forum, I will give you my e=mail address and you can send pics that way. This should be a relatively easy fix. Roger Link to comment Share on other sites More sharing options...
Jim Gell Posted February 21, 2016 Report Share Posted February 21, 2016 Until you get it fixed, you might slip some cheap thin cutting boards in to protect carpet from tearing. Jim 2001 Volvo 770, Detroit 60 Series, Gen 2 Autoshift Passenger assist elevator to enter cab - for when we need it, or sell it? '05 Travel Supreme Select 40 RLQSO 5th wheel 2016 smart car We started full timing on December 1st 2014 Travel is fatal to prejudice, bigotry, and narrow-mindedness - Mark Twain Not all that wander are lost - J. R. R. Tolkien Link to comment Share on other sites More sharing options...
rdickinson Posted February 21, 2016 Report Share Posted February 21, 2016 Good idea, go to the hardwood floor dept in Lowes or Home Depot, you should find the plastic slides used to protect the floor when sliding appliances in or out. http://www.amazon.com/Glide-N-Guard-Prevents-Damage-Movement-Appliances/dp/B001DPUU7E http://www.homehardware.ca/en/rec/index.htm/Hardware/Builders/Floor-Protection/Glides/6-Pack-Appliance-Glide-and-Guard-Tracks/_/N-ntjpq/R-I2324050?Num=0 Link to comment Share on other sites More sharing options...
