ruthanns1 Posted January 3, 2016 Report Share Posted January 3, 2016 Hey Guys, we have a problem with our batteries charging. Our amp meter in the truck reads less then 11amps even with the on board charger on and it dose not charge the batteries. I can't get a date on the batteries none of the numbers were removed. I tried jumping it by the two nubs under the hood and nothing. Now I have 4 batteries and they seem to be in two banks run parallel, and I'm guessing that they join under the truck some where. Do I need a special charger for charging a two or four battery bank. Thanks Chip and Ruth Link to comment Share on other sites More sharing options...
rickeieio Posted January 3, 2016 Report Share Posted January 3, 2016 First, you ought to see if the alternator is really charging. I use a simple K-D ammeter, inductive type. Just place it over the alternator wire and see if it registers. No, it's not precise, but that's not really important here. If your alternator is charging, check ALL connections, especially grounds. Give 'em all a tug to be sure they're tight, and if there's a loose one, take it apart and clean it. Take off every battery connection and clean it too. I've been fighting electrical gremlins too. Being impatient, I whizzed right past the basics and caused myself a lot of wasted time. Basics first.......... Link to comment Share on other sites More sharing options...
ruthanns1 Posted January 4, 2016 Author Report Share Posted January 4, 2016 First, you ought to see if the alternator is really charging. I use a simple K-D ammeter, inductive type. Just place it over the alternator wire and see if it registers. No, it's not precise, but that's not really important here. If your alternator is charging, check ALL connections, especially grounds. Give 'em all a tug to be sure they're tight, and if there's a loose one, take it apart and clean it. Take off every battery connection and clean it too. I've been fighting electrical gremlins too. Being impatient, I whizzed right past the basics and caused myself a lot of wasted time. Basics first.......... Rick, I'm in Colorado and as soon as the snow melts around the truck I will start to check all the connection and hope it is just a loose wire. Thanks for all your advice. Link to comment Share on other sites More sharing options...
