SKP101479 Posted July 16, 2015 Report Share Posted July 16, 2015 When air pressure reaches max there's a 'chuf, chuf' sound from under the truck. This occurs every few minutes often 'chuffing' 3-5 times per occurrence. Must be some high air pressure relief valve? Thanks in advance, J&V J&V with Edina (RIP), the wonder dobie andNet Proceeds our 2005 Volvo VNL630 256" WB. Focus SVT on the back, in the garage. ET Hitch controlling the articulation. Jackalopee controlling the 'juice'. 2002 Teton 39' Grand SundanceAll still a work in progress.Photos and comments at http://gallery.ournetproceeds.com Link to comment Share on other sites More sharing options...
Broncohauler Posted July 16, 2015 Report Share Posted July 16, 2015 That's the air dyer releasing some air to Keep moisture out of your sir system. Totally normal doing what it should unless it's happening more than once every couple minutes. Link to comment Share on other sites More sharing options...
dennisvr Posted July 16, 2015 Report Share Posted July 16, 2015 What's the air pressure at cut out? "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
SKP101479 Posted July 16, 2015 Author Report Share Posted July 16, 2015 ..It's every couple minutes and some times seems to stumble as in 3-4 partial 'chufs'. J&V with Edina (RIP), the wonder dobie andNet Proceeds our 2005 Volvo VNL630 256" WB. Focus SVT on the back, in the garage. ET Hitch controlling the articulation. Jackalopee controlling the 'juice'. 2002 Teton 39' Grand SundanceAll still a work in progress.Photos and comments at http://gallery.ournetproceeds.com Link to comment Share on other sites More sharing options...
lappir Posted July 16, 2015 Report Share Posted July 16, 2015 I had that issue shortly after purchasing my truck. I changed the cartridge filter under the truck but still happened. My mechanic in Fremont, Ia. was able to rebuild the valve that was the problem near the filter. Less than $50, new valve assembly >$100 I think. That was at least 7 years ago. Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
SnaykeByte Posted July 17, 2015 Report Share Posted July 17, 2015 Sounds to me like one of the relief valves might be popping off. "JOE DIRT"--1994 Volvo WIA64TES VED12, 425HP, SUPER 10, SINGLED, 370 REARS, DOMETIC AUXILLARY A/C, ONAN QD10000 GENNY2006 Fleetwood Wilderness Advantage AX6 40ft"I'm not in right now.......I'm out finding myself. If I get back before I return, leave me a message and one of us will get back to you..??" I'm right 97% of the time.........and nobody cares about the other 4% Link to comment Share on other sites More sharing options...
dennisvr Posted July 17, 2015 Report Share Posted July 17, 2015 Sounds to me like one of the relief valves might be popping off. That's what I was thinking also, that's why I was wondering what the pressure was at air governor cut out. "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
porky69 Posted July 18, 2015 Report Share Posted July 18, 2015 More likely it is the purge valve chattering. New one is around $100 and takes about 15min to change. Link to comment Share on other sites More sharing options...
