Mastercraft Posted June 19, 2015 Report Share Posted June 19, 2015 I was sliding around under the coach to put in my new hydraulic lines for a 6 point leveling system mod I am doing and noticed some opportunities to seal the belly material better around various openings and on the edges. Is CRL Black 777 Butyl Rubber Sealant the stuff to use? thanks Rich 2009 Volvo 780 D16 535hp 1850 ft-lbs I shift 3.36 Thermo King Tripac APU DIY Bed and Frame Extension ET Hitch, Stellar EC2000, EcoGen 6K 2002 F350 CC Dually w/ Lance 1181 2012 Mini Cooper S 2007 Teton Royal Freedom " The only place you will find success before work is the dictionary " Link to comment Share on other sites More sharing options...
Kirk W Posted June 20, 2015 Report Share Posted June 20, 2015 That could work well. A lot depends upon where the opening is and how large it is. In some cases I like to use one of the expanding foam products, but if you do so use care to allow enough space for the foam's expansion. I would not use any silicone based caulking as silicone products do seal well, but once cured nothing will stick to them, not even more silicone so they must be removed 100% before making any repairs to the area. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
