bigredhdt Posted June 22, 2019 Report Share Posted June 22, 2019 I have kodiak disc brakes on my trailer. The mount consist o a rubber sleeve that fits inside the caliper, the a stainless tube, inside the tube is where the mounting bolt goes. Grease goes between the rubber bushing and the stainless tube. I have used anti-sieve which is not the right application, now I use the disc caliper grease, but in one year it is no longer any use. Any suggestions out there? Quote Link to comment Share on other sites More sharing options...
Shawn Patterson Posted June 23, 2019 Report Share Posted June 23, 2019 This is what I've used on all my vehicles. Permatex 24125 Ceramic Extreme Brake Parts Lubricant, 8 oz. https://www.amazon.com/dp/B0018PSASU Quote Shawn and Andrea Elvis the Cheagle Dog 2013 Volvo 730 / iShift / D13 XE Package / ET Hitch 2016 DRV Mobile Suites 43 Atlanta 2018 Jeep Wrangler Rubicon Unlimited Read the blog at 40foothouse.com Link to comment Share on other sites More sharing options...
WeBeFulltimers Posted June 23, 2019 Report Share Posted June 23, 2019 12 hours ago, Shawn Patterson said: This is what I've used on all my vehicles. Permatex 24125 Ceramic Extreme Brake Parts Lubricant, 8 oz. https://www.amazon.com/dp/B0018PSASU I went to your link to have a look and couldn't believe the condition of the rotors in the pictures provided showing the product in use. Good product though. Quote Fulltiming since September 1, 2010 2012 Ford F-350 PSD SRW Lariat Crew Cab 2012 Montana 3585SA Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted June 23, 2019 Report Share Posted June 23, 2019 I use the same synthetic brake lube that Shawn uses. The older, non ceramic version was a green color, the new ceramic lube is a purple color but either one worked great. Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
bigredhdt Posted June 24, 2019 Author Report Share Posted June 24, 2019 That product says for metal to metal contacts. This is metal to rubber. Quote Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted June 25, 2019 Report Share Posted June 25, 2019 Well I guess I have been screwing up since 1972 when I started working as a mechanic at dad's garage. I will say this much, if you ask 100 techs what they use, all of them will use either that product or a very similar one. Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Sehc Posted June 25, 2019 Report Share Posted June 25, 2019 There are many silicone products if you are worried. I and others use synthetic grease. Quote Link to comment Share on other sites More sharing options...
dan412 Posted June 27, 2019 Report Share Posted June 27, 2019 I use stuff called Sil - glide works good. Quote 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
