Chuck Posted April 22, 2019 Report Share Posted April 22, 2019 I need to replace 2 running lights. 2003 Volvo vnl 610, 4 diode. Any source? What is the oem item part number. Looked at Raneys. They reference the oem #. Also a little pricey. Link to comment Share on other sites More sharing options...
rickeieio Posted April 22, 2019 Report Share Posted April 22, 2019 I'm guessing you're referring to the overhead clearance lights? Be aware, they come with, or without, the pig tail wires. We needed two w/ pigtail because the plug was corroded beyond use. Tried to get them from WorldWide and they didn't have a part number for them. Went to another nearby truck place that hade them in stock. And then..... if you do have to rewire, check before wrestling everything back into place. I found white wire connects to the black wire and vicey-versey. LEDs are polarity sensitive and Volvo wiring doesn't always make sense. BTW, if you're at the ECR, I'll have some with me. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Av8r3400 Posted April 23, 2019 Report Share Posted April 23, 2019 Rick: One of my clearance lights is dim compared to the rest. Do you think that's just corrosion in the harness? Av8r34002012 Volvo VNL 730 D13 iShift & 2021 Grand Design Momentum 397TH I'd rather die trying to live - Than live trying not to die. -Leonard Perry Link to comment Share on other sites More sharing options...
rickeieio Posted April 23, 2019 Report Share Posted April 23, 2019 Possible, but maybe it's gotten moisture in it. Beware, accessing the clearance lights on a Vovlo is not easy, especially if you're old and short for your weight (fat). There's no good place to stand on our truck w/ ISX, maybe Volvo motors offer a better perch. I looked for my spare lights this morning but didn't find them. I know I have at least two without pigtails. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
