PEIFamily Posted September 16, 2018 Report Share Posted September 16, 2018 Had an issue with my EPG shutter awhile back and had the shop temp disabled the airline to test it. I was happy with the engine braking (one stage was disabled) and never bothered to fix it. This spring it was stuck again and noticed the baffle was really loose. I was going to get it rebuilt, but has anyone removed it instead and any concerns with doing so? I was thinking of popping the can off and cutting the shutter out to prevent any future restriction. (This would save throwing $1000 into it as the baffle/shutter is bad and they were not sure if the valve was causing the origional problems). Does anyone know if I will have any future problems by cutting this out? Thanks! Jason Quote 2006 Volvo 670 singled long 2011 Heartland Sundance 3300CK 2006 Smart passion 2001 F350 DRW CREWCAB Link to comment Share on other sites More sharing options...
Nigel Posted September 16, 2018 Report Share Posted September 16, 2018 Jason Are saying yours failed partially applied? Also your estimate on the rebuild kit is about six or seven hundred Canadian dollars low. I just went through this with the dealer yesterday as well as the air valve, time to skip town before credit card bill comes in. I am not a mechanic but I see no reason not to gut governor or at least weld it open if it is causing problems. Nigel Quote 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
jeffw Posted September 16, 2018 Report Share Posted September 16, 2018 Without the EPG the truck could be slower to warm up, and may struggle to stay at temperature for extended idles in cold weather. Quote 2007 Volvo 780 Volvo D12D, 465hp, 1650 ft/lbs tq., ultrashift Link to comment Share on other sites More sharing options...
RandyA Posted September 18, 2018 Report Share Posted September 18, 2018 Jason, Other than exhaust braking and warming up the engine the shutter and "donut" in the exhaust are there to enhance the EGR function. There is also a restrictor between the turbo and manifold to increase exhaust pressure for the EPG/EGR assembly. Charlie (SCLord) and I have bounced questions back and forth during our winters in Florida about going whole hog and removing the restrictor which looks like a big washer with a 2" hole, the EPG valve and the restrictor plate/gasket at the turbo. Of course, this would impact the EGR function so someone "might" want to think about the EGR delete kit. Illegal if the Smog Police do an inspection. Since "we" are not living in colder climates I have little concern about the warm-up time. From what I can discern removing the EPG by itself "may" be OK but you could create some EGR malfunctions by doing so. If you go that route I will be very interested in your results. Quote Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
PEIFamily Posted September 18, 2018 Author Report Share Posted September 18, 2018 (edited) Well, I pulled it off today (lack of room to remove it forced me to take it off in two parts (3 of 4 bolts snapped off in the exhaust housing when removing the can, but will deal with those Thursday) Soon as I got it off, the shutter pulled right out, Looks like it was snapped off halfway up the rod? (This would account for the problem I had this spring if the shutter moved and got pinned closed temporarily). I have had my epg disabled for the last almost 2 years so the warmup don't concern me too much. I also have been running the egr delete from otr for the last 3 or so years (works great). I am somewhat ok with just using the engine brake only and not the epg brake so I may just make a plate up and delete it for now until I get stateside again for a cheaper rebuild kit on it. I will look for the restrictor as well. I just got it off and had to leave so I never had any time to snoop around it yet. I also finally pulled off the compressor to replace my rusty inspection plugs (found a machine shop that makes them on an as needed basis for a Volvo dealer here). While under there, I am replacing most of the exhaust pipe under the cab (leave it to me to do three projects at one time) lol. Edited September 18, 2018 by PEIFamily Typo Quote 2006 Volvo 670 singled long 2011 Heartland Sundance 3300CK 2006 Smart passion 2001 F350 DRW CREWCAB Link to comment Share on other sites More sharing options...
Black Posted June 14, 2020 Report Share Posted June 14, 2020 On 9/17/2018 at 10:42 PM, PEIFamily said: Well, I pulled it off today (lack of room to remove it forced me to take it off in two parts (3 of 4 bolts snapped off in the exhaust housing when removing the can, but will deal with those Thursday) Soon as I got it off, the shutter pulled right out, Looks like it was snapped off halfway up the rod? (This would account for the problem I had this spring if the shutter moved and got pinned closed temporarily). I have had my epg disabled for the last almost 2 years so the warmup don't concern me too much. I also have been running the egr delete from otr for the last 3 or so years (works great). I am somewhat ok with just using the engine brake only and not the epg brake so I may just make a plate up and delete it for now until I get stateside again for a cheaper rebuild kit on it. I will look for the restrictor as well. I just got it off and had to leave so I never had any time to snoop around it yet. I also finally pulled off the compressor to replace my rusty inspection plugs (found a machine shop that makes them on an as needed basis for a Volvo dealer here). While under there, I am replacing most of the exhaust pipe under the cab (leave it to me to do three projects at one time) lol. I know this is old but how's your truck running with the deleted EPG brake? I'm thinking of doing the same thing tomorrow and was searching for any been there/done that accounts. On 9/17/2018 at 10:42 PM, PEIFamily said: Quote Link to comment Share on other sites More sharing options...
Parrformance Posted June 14, 2020 Report Share Posted June 14, 2020 Have you checked to find a used one and just replace it? It can bench shacked for proper operation, by applying sir to the inlet port. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
PEIFamily Posted June 14, 2020 Author Report Share Posted June 14, 2020 12 hours ago, Black said: I know this is old but how's your truck running with the deleted EPG brake? I'm thinking of doing the same thing tomorrow and was searching for any been there/done that accounts. No problem at all.. I loose a shade amount of engine brake I think but I never noticed much of a difference. Quote 2006 Volvo 670 singled long 2011 Heartland Sundance 3300CK 2006 Smart passion 2001 F350 DRW CREWCAB Link to comment Share on other sites More sharing options...
Black Posted June 15, 2020 Report Share Posted June 15, 2020 20 hours ago, Parrformance said: Have you checked to find a used one and just replace it? It can bench shacked for proper operation, by applying sir to the inlet port. I've looked for used ones but haven't had much luck yet. I have the two stage though so I'm fine with just plugging the air line and running it with one stage left until a great deal falls into my lap. At this point, I'm just trying to get all the systems refurbished and get her back on the road and this is a non-essential to-do. Quote Link to comment Share on other sites More sharing options...
Black Posted June 15, 2020 Report Share Posted June 15, 2020 20 hours ago, PEIFamily said: No problem at all.. I loose a shade amount of engine brake I think but I never noticed much of a difference. Thanks for the feedback, it's DEFINITELY appreciated! Quote Link to comment Share on other sites More sharing options...
