jdhm Posted April 11, 2018 Report Share Posted April 11, 2018 Anyone have suggestions for good motor home front end alignment place inow Colorado Springs? Link to comment Share on other sites More sharing options...
Chris-n-Dennis Posted April 12, 2018 Report Share Posted April 12, 2018 Freightliner or Spartan chassis? If Freightliner then TransWest in Fountain. Have not been there but have only heard good things. Note: You do pay for what you get. Berkshire XL 40QL Camphosting and touring Our blog: cndtravels.blogspot.com Link to comment Share on other sites More sharing options...
WILDEBILL308 Posted April 12, 2018 Report Share Posted April 12, 2018 I would recommend an all wheel alignment. You should also be loaded like you were headed out on a trip. I did full fuel, water and 50% black and gray also ful propane. The usual clowes, food ect.The reason is the weight will change your alignment. Bill 2008 Newmar Mountain Aire model 4521 450 hp Cummins ISM Allison 4000MH tran. Towing a 2014 Honda CRV with a blue Ox tow bar Home base Fort Worth Texas A man who carries a cat by the tail learns something he can learn in no other way. -Mark Twain- Link to comment Share on other sites More sharing options...
Ray,IN Posted May 6, 2018 Report Share Posted May 6, 2018 On 4/12/2018 at 4:17 PM, WILDEBILL308 said: I would recommend an all wheel alignment. You should also be loaded like you were headed out on a trip. I did full fuel, water and 50% black and gray also ful propane. The usual clowes, food ect.The reason is the weight will change your alignment. Bill Right! When the local HDT repair shop aligned my MH, the rear axle was out by 3/4"(thrust angle) It cost $300, and well worth the money. Our MH now drives better than it ever did. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
