Sir Traveller Posted March 26, 2018 Report Share Posted March 26, 2018 hello everyone I am new to Rvs, a couple of months ago I bought a 2003 Ford V10 ( 4 wind hurricane ) , I installed 2 deep cycle batteries and just want to know how often should I recharge them, and what are the actual steps of recharge ( I read online 3 steps to recharge the barraties but no details of how to exactly do each step ) . I am currently in a full RV hookup in San Diego, it is getting warmer here ( 70 to 80s / if that affect how often the batteries are recharged !?!!) I will appreciate any tips thank you. ( updated / edited ) I meant to say how often should I maintain the batteries ( refill water if it is below certain level ) not how often to recharge them ( that part I can tell from the test button obviously ) Link to comment Share on other sites More sharing options...
Kirk W Posted March 26, 2018 Report Share Posted March 26, 2018 Welcome to the Escapee forums! Good to have you with us. There are two ways that your house batteries get recharged under normal use. The first is that when you drive the RV there is a relay that connects the house batteries to the chassis battery system and it will charge the house batteries as well as the chassis battery while you are driving the RV. That method does a very good job of charging but there is also what is called a converter which when you park and connect to the shore power system of the RV park, it converts the 120V-ac power into 12V-dc power to supply things like your lights, furnace, water heater and refrigerator controls circuits as well as the fresh water pump. Your power cord supplies 120V-ac power like you use in a house to the RV and that then powers the converter, the TV, microwave, and all of the outlets in the RV. Some RVs have an inverter that can take power from the batteries and supply some of the 120V systems but usually only a few selected items. You can tell what you have by seeing if your TV will work when you are not plugged into shore power. If your RV has an onboard generator set to supply 120V power, that acts exactly the same is if you were connected to shore power. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Sir Traveller Posted March 26, 2018 Author Report Share Posted March 26, 2018 thank you Kirk... so if I understood your reply correctly, this means whether I am driving, or parked and hooked up to electricity, both ways the batteries will be automatically recharged ? Link to comment Share on other sites More sharing options...
Chad Heiser Posted March 27, 2018 Report Share Posted March 27, 2018 When I had lead acid deep cycle batteries, I would check the water level once a month. Sometimes they needed water and sometimes they didn’t, but I always did it monthly. You can make the chore much easier by adding a watering system to your batteries. Like this one for example: https://www.amazon.com/Flow-Rite-RV2000-Pro-Fill-Battery-Kit/dp/B001FCAXT0/ref=sr_1_1?ie=UTF8&qid=1522119421&sr=8-1&keywords=battery+watering+system 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
mscans Posted March 27, 2018 Report Share Posted March 27, 2018 Sir T. your RV is old enough that it probably does NOT have a 3 or 4 stage charger built in to the converter. you may want to look into that to see about an upgrade. the newer systems do a much better job of charging and will allow the batteries to last longer, charge faster and work better. enjoy the new (to you) RV and get out as often as you can. Happy Trails, Florida Mike EXPERTS AREN'T!! Link to comment Share on other sites More sharing options...
Kirk W Posted March 27, 2018 Report Share Posted March 27, 2018 13 hours ago, Sir Traveller said: whether I am driving, or parked and hooked up to electricity, both ways the batteries will be automatically recharged ? If we assume that everything is working properly, that is correct. Both of the other replies are also valid as well. The RV industry has improved the type of converters in common use and the earlier models had converters that were of pretty poor charge capability and so only supplied a single, constant voltage to the battery system while better quality converters have a voltage regulator that does a much better job of battery maintenance. I think that it would be helpful to you if you read the following article that was written and posted by a member of the Escapees Club staff. The 12V Side of Life Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
richfaa Posted March 28, 2018 Report Share Posted March 28, 2018 Check your water levels on a regular basis.Every month will not hurt. Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
