Fluids for power steering
tippey
Hi
i repaired my return hose to the power steering reservoir but lost a lot of fluid in the process.
Need to replenish but don’t know it’s capacity or what was in there! It was reddish clear fluid. I cannot find a manual showing recommended fluids or capacities yet. It may be atf fluid my CD with fluids info in missing...
I do not want to depart until I can get a reading on the dip stick.
Can you suggest what type of power steering fluid I can buy and how big the reservoir probably is?
VNL64T660 2001 VED12 Engine
520-405-9125 stippey47@gmail.com
or please reply
thanks,
Steve Tippey ( tipper)
"GAR" is a 2001 White Volvo 660 singled long w/ VED12 465 3.58 - Eaton Fuller Auto-shift 10spd. 3 pedal- Onan QD 6500 Gen. (aka "Joyrider")
2010 Carriage Royals International 36MAX1 w/ MORryde IS, G114's 17.5" wheels, (SOLD)
2014 Honda CRV AWD (ready to flat tow but driven separately by my DW!
Class of 2016 Full-Timers
Power Steering Reservoir
The power steering fluid reservoir is filled with Automatic
Transmission Fluid (ATF) Dexron
steering system. Change fluid every 240,000 km
(150,000 miles). Change filter every year or more often
if necessary.
If the fluid has darkened, it indicates the power steering
system is running hotter than normal and the fluid is
overheating. Troubleshoot for possible overheating and
change the fluid.
The Power Steering Reservoir fluid is maintenance free
and should only be changed in the event of required
maintenance as a result of mechanical failure.
For more information on Steering refer to Se
2006 Volvo VNL 780, " Arvey"  Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift
2003 Jeep Wrangler Rubicon
2010 Forest River Coachman Freedom Express 280RLS
Jackalopee
vo Trucks North America
Service Bulletin
Power Steering, Lubrication
if necessary.
change the fluid.
For more information on Steering refer to Service
Information in Group 6 and appropriate vendor literature
Jackalopee
Good to check the manual on such things.
And just to be difficult lots of Freightliners use the same motor oil that is used in the engine, a decal is on the reservoir but sometimes cannot be read. Have no idea what Paccar or International do. When in doubt, read the instructions...
Jeff Beyer temporarily retired from Trailer Transit
2000 Freightliner Argosy Cabover
2008 Work and Play 34FK
Homebase NW Indiana, no longer full time
Steve,
According to the Volvo service guide, you should use trans fluid.  Same as my 2013 VNL730.
Power Steering Reservoir: The power steering fluid reservoir is filled with Automatic Transmission Fluid (ATF) Dexron® III for the power steering system.
https://volvotrucks.vg-emedia.com/ProductDetail.aspx?ProductId=7418&GroupId=593
Shawn and Andrea
Elvis the Cheagle Dog
2013 Volvo 730 / iShift / D13 XE Package / ET Hitch
2016 DRV Mobile Suites 43 Atlanta
2018 Jeep Wrangler Rubicon Unlimited
Read the blog at 40foothouse.com
Sheppard 92's were the ones that only take engine oil.  They've all been OK'd with engine oil actually but you lose some on the max temp (don't dry steer it and don't hold at poppets - but a guy should drive truck like that anyways) and you have to change oil every 50K.  So ATF is probably the better choice if you have a TAS or Sheppard M.
