CrazyCooter Posted August 23, 2015 Report Share Posted August 23, 2015 Going to start accumulating parts and working on a plan for installing my Magnum MS-2012 inverter/charger soon, but have not seen much talk or pics of installs on here. Mostly concerned with getting battery cables from the bank/box to the sleeper and with the air ride's flex what is the best solution. Through the floor bulkheads? I'm planning to just run off the trucks starting bank of 3 group 31's or appox. 300Ah (might add a 4th battery) as I don't plan to really camp much in the sleeper or have many loads other than a refer. This truck's alternator is quite small at 105A so it won't recover all that fast.....May have to step up to a 200A replacement and/or get some solar on the roof. Have been looking at the flexible panels of 60-120 watts and bonding them to the roof for a clean aerodynamic look although they aren't the cheapest or most efficient options. I do plan to have my Honda 3000is mounted on board someday.... Also wondering what kind of nightmare the panel mounting will cause when I decide to paint the truck...... The previous owner started the electrical system, but will likely scrap most of it other than the 2 breaker load center and 30a twist-lock at the rear of the cab. I'm also thinking about running a circuit to one of the toolboxes for cordless tool charging and other stuff. 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
RandyA Posted August 24, 2015 Report Share Posted August 24, 2015 Bring your cables (both + and -) off of the batteries with an in-line disaster fuse. Go through the floor with insulated bulkhead fittings and leave adequate slack so that the cab movement does not pull the outside cables tight. #0 copper welding cable is made of fine strands and thus will not be harmed by movement of the cab. Keep in mind the group 31 batteries in your truck are designed for starting (thin plates, high initial current) and not sustained deep discharge. You might want to consider a second battery bank consisting of series connected 6V golf cart batteries. Sounds like you have a good plan going. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
Chad Heiser Posted August 24, 2015 Report Share Posted August 24, 2015 I tried running my Magnum 2012 off the truck battery bank (3 batteries) to power a small dorm style fridge. I made it about half an hour into a trip before my truck DID started throwing low voltage codes. I turned the inverter off and the codes went away. I ultimately added a separate battery bank of AGM batteries under the couch in the sleeper to power the inverter. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Chad Heiser Posted August 24, 2015 Report Share Posted August 24, 2015 I have posted a basic diagram of my system in my truck in the past, but I just searched through old posts and couldn't find it. It must have dropped off when the forum upgraded the last time. If you are interested I think I still have the diagram saved somewhere and I can repost it. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 24, 2015 Author Report Share Posted August 24, 2015 Thanks guys! The pass through bulkhead fittings are what I had envisioned as the safest and cleanest way. I had originally planned a separate bank of batteries, but would prefer not if I can avoid it. Less stuff to buy and maintain the better these days.....If I can't have popcorn and leftovers while on the road without more batteries, guess it's more batteries! I have been using one of those cheesy Coleman 12v coolers and it cools fine, but I think the current consumption does get to be a little much unless you are driving the truck everyday and not plugged in. One of those compressor drawer style refers would be cool for under the bunk. Just had one of my AGM 8D's bite it and almost caused the solar to wipe out all of them! Caught it just in time. They are only 4 years old and we'll cared for...... wondering if the others are right behind it or if I have time for the LiFePO4 technology to catch up and get cheaper. 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted August 24, 2015 Report Share Posted August 24, 2015 I have been using a Tripp-Lite 2000 watt inverter/charge for 10 years now. We are normally plugged in while stopped and run the inverter for the refrigerator and the truck computer while traveling. Details with schematics RR Inverter/Charger Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
CrazyCooter Posted August 24, 2015 Author Report Share Posted August 24, 2015 I have been using a Tripp-Lite 2000 watt inverter/charge for 10 years now. We are normally plugged in while stopped and run the inverter for the refrigerator and the truck computer while traveling. Details with schematics RR Inverter/Charger Perfect Mark! I will probably skip the input breaker as the Magnum has one and whatever I plug into will also be fused. You guys really get into these drawings! I have always thought it out in my head and just worked from that.....although as I get older, I'm finding my RAM has become more and more "corrupt and unstable". 1999 Peterbilt 385 C12 430/1650 13spd 2006 Dodge 3500 DRW 4x4 2010 Hitchhiker Champagne 36 LKRSB Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted August 24, 2015 Report Share Posted August 24, 2015 There is a purpose to the input breaker more than protecting from over-current. The input breaker will also protect from a backward wired power source. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
