KodiakJack Posted June 15, 2023 Report Share Posted June 15, 2023 (edited) The switch is part of our rigs Level Up system. It is used to raise and lower the front hydraulic jacks. The old switch, operated momentary in both directions, is labeled YIS DC 12V 16A (Made in Taiwan) and has 6-pins (though only 4 wires leave it). Unfortunately it does not function at all so I am unable to determine it's operation with my ohm meter. As pointed out only 4 wires are connected to the system with the red and blue split and landing on 2 switch pins. This switch failed a couple years back and my attempt then to replace it with a 4-pin momentary while on the road did not work so I have used the Level Up main panel for the front jacks ever since. Why now? The Level Up panel is showing a "External Sensor" error (another request for help topic I will soon post) leaving me unable to use the main panel as I was. Later, J Edited June 15, 2023 by KodiakJack typo Quote 2012 Landmark, San Antonio 2013 Silverado CC, 3500HD, Duramax, DRW, 4x4 Backup, side and hitch cameras, Tireminder TPMS Link to comment Share on other sites More sharing options...
Danfreda1 Posted June 15, 2023 Report Share Posted June 15, 2023 Look up rv surplus parts in white pigeon michigan. We were there a few weeks ago and they had a lot of those kid of switches. bontragers rv surplus was the one we were at. Worth a call Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 16, 2023 Report Share Posted June 16, 2023 Go to any local auto parts store. Buy yourself a common Double Pole/ Double Throw momentary switch, rated for at least as much as the original switch. DC motors reverse by swapping the power/ground wires. 2 of the wires will go to the motor, the other 2 are 12v in, and ground. Connect the new switch as the old, rest easy. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
KodiakJack Posted June 16, 2023 Author Report Share Posted June 16, 2023 I will find a 6-pin DP/DT momentary and change it out. Thank you both for your help. Later, J Quote 2012 Landmark, San Antonio 2013 Silverado CC, 3500HD, Duramax, DRW, 4x4 Backup, side and hitch cameras, Tireminder TPMS Link to comment Share on other sites More sharing options...
KodiakJack Posted July 5, 2023 Author Report Share Posted July 5, 2023 My forward up/down station is back to working. Thanks for the help. Later, J Quote 2012 Landmark, San Antonio 2013 Silverado CC, 3500HD, Duramax, DRW, 4x4 Backup, side and hitch cameras, Tireminder TPMS Link to comment Share on other sites More sharing options...
Ray,IN Posted July 6, 2023 Report Share Posted July 6, 2023 Jack, for future needs, DigiKey electronics carries about everything. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
KodiakJack Posted July 6, 2023 Author Report Share Posted July 6, 2023 👍 Later, J 18 hours ago, Ray,IN said: Jack, for future needs, DigiKey electronics carries about everything. Quote 2012 Landmark, San Antonio 2013 Silverado CC, 3500HD, Duramax, DRW, 4x4 Backup, side and hitch cameras, Tireminder TPMS Link to comment Share on other sites More sharing options...
