Al F Posted January 6, 2022 Report Share Posted January 6, 2022 (edited) Does anyone have a source for the o-rings needed when you replace the battery in the TST 507 Cap-Style sensors? I need to replace the batteries in my TST 507 Cap-Style TPMS sensors, but I need a source for the o-rings. When I unscrew the cap to access the battery the o-ring tears apart. I have looked on Vulcantire.com where I bought the sensors, but they want an arm and a leg for the o-rings and batteries as a package. $24 for a set of 10. The o-rings should be just nominal cost and the batteries are not expensive at the store or Amazon. I did try to do a search on this forum, but don't get any hits for "TPMS AND ring" or "TPMS AND rings" Edited January 6, 2022 by Al F Quote Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
Dutch_12078 Posted January 6, 2022 Report Share Posted January 6, 2022 I've been using these 10x12 mm O-rings from Amazon. $5.49 for 20. https://www.amazon.com/uxcell-Rings-Nitrile-Rubber-Diameter/dp/B07FRDHVHX/ Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Al F Posted January 6, 2022 Author Report Share Posted January 6, 2022 11 hours ago, Dutch_12078 said: I've been using these 10x12 mm O-rings from Amazon. $5.49 for 20. https://www.amazon.com/uxcell-Rings-Nitrile-Rubber-Diameter/dp/B07FRDHVHX/ Thanks for the quick response and excellent info. I also finally found a thread in this forum where others discussed this topic: There is a link in the above thread for pretty much the same o-rings. https://www.amazon.com/uxcell-100Pcs-Nitrile-Sealing-Grommets/dp/B01MTNZLGL Quote Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
Al F Posted January 6, 2022 Author Report Share Posted January 6, 2022 (edited) Also in the same thread I mentioned above: https://www.amazon.com/uxcell-100Pcs-Nitrile-Sealing-Grommets/dp/B01MTNZLGL a couple people wrote that they did {edit) NOT put o-rings back on when they just replaced the battery. They put a dab of silicone plumbers grease on the threads and that worked fine. I meant to write that some people did NOT put o-rings back on. Edited January 6, 2022 by Al F Quote Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
Dutch_12078 Posted January 6, 2022 Report Share Posted January 6, 2022 I found the 11mm rings to be a little too tight, making them hard to install and more prone to breakage. The 12mm rings work better for me... Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
sundancer268 Posted January 6, 2022 Report Share Posted January 6, 2022 I use Silicone Grease on my O-Rings and get several years on each O-Ring. Dow DC-4 or DC-11 depending what I grab from my tool box. Quote U.S. Navy GSMC(SW) (RETIRED) 1993-11-01, 26 years service with 23 years of that active and 3 years reserve. Now retired after 20 years at local hospital in the maintenance department. 1995 Gulf Stream Scenic Cruiser 34' DP W/6Spd Allison. Road Master Sterling All terrain, Air Force One, towing new 2019 Jeep Cherokee Elite Link to comment Share on other sites More sharing options...
Star Dreamer Posted January 7, 2022 Report Share Posted January 7, 2022 We haven't replaced any of our orings on our TST 507 sensors in the 10 years we have been using them. Usually changing out the batteries about once a year, sometimes longer. We have 12 sensors and in those 10 years, I think I have replaced 5 sensors and three of those were for breakage. I did on the beginning put a little bit of RTV sealant on the threads but haven't lately. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
