Higginbothamtravels Posted September 21, 2021 Report Share Posted September 21, 2021 Our High Pointe EC028BMR convection oven will not heat. It runs fine but never gets hot. The microwave portion also works. It's just the convection portion that doesn't heat. It runs and the plate turns but never gets hot at all. Is there an internal fuse that could be blown? We checked all the RV fuses and breakers. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 21, 2021 Report Share Posted September 21, 2021 Welcome to the forums! Good to have you join us. I assume that you probably already have the instruction manual that I found online. The fuse should be located inside the shroud cover, where the cord goes into the microwave. I am unable to find any sort of repair manuals for it. Quote Link to comment Share on other sites More sharing options...
LowOnCash Posted September 22, 2021 Report Share Posted September 22, 2021 I hate to say it but there is a 90% chance you're not operating it correctly - it took us nearly a day to figure out the goofy sequence to get our Micro to work properly - there is usually an 800 number - call them while the micro is in front of you good chance they can get you going! Regards - Mike Quote Link to comment Share on other sites More sharing options...
lawdg Posted May 8 Report Share Posted May 8 i have the same issue. it worked fine yesterday, so i assure you its not user error. Any ideas on what the fix is? Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted May 8 Report Share Posted May 8 Check that the unit is getting enough electricity . We had a similar thing happen . It was the wall plug . The lower receptacle somehow was not letting full current through , but , the upper one was up to snuff . Likely poor connections inside . Quote Link to comment Share on other sites More sharing options...
RV_ Posted May 9 Report Share Posted May 9 (edited) Here are a bunch of YouTubes about that oven: https://www.youtube.com/results?search_query=High+Pointe+EC028BMR+convection+oven+will+not+heat Pat and Pete's suggestion may be a fix too if it is the outlet. I keep a cheap outlet tester that can check basics and even check pedestal outlets with an adapter. I go to it first as it is easiest. Then pull out the Multi-meter if that shows nothing. Example: Fluke is a top instrument maker and their outlet tester is affordable. Example of price: https://www.amazon.com/Fluke-ST120-Socket-Tester-Audible/dp/B0B3VCZ4XK Edited May 9 by RV_ Quote Link to comment Share on other sites More sharing options...
Kirk W Posted May 9 Report Share Posted May 9 (edited) On 5/8/2023 at 9:36 AM, lawdg said: Any ideas on what the fix is? Most models have an internal fuse. It is possible that there is a connection problem of some sort but to know that you need to monitor the voltage across the appliance while it is turned on. I'm guessing that is what Pet means by too little electricity. Do you have a meter to troubleshoot with? Edited May 9 by Kirk W Quote Link to comment Share on other sites More sharing options...
RV_ Posted May 10 Report Share Posted May 10 Let us know how it works out. Quote Link to comment Share on other sites More sharing options...
AndrewT Posted June 6 Report Share Posted June 6 Convection oven during pre heat function will not reach the temperature setting and then starts to decline in temperature. Was a solution to this specific issue posted versus just the power fuse blowing ?? Quote Link to comment Share on other sites More sharing options...
RV_ Posted June 6 Report Share Posted June 6 4 hours ago, AndrewT said: Convection oven during pre heat function will not reach the temperature setting and then starts to decline in temperature. Was a solution to this specific issue posted versus just the power fuse blowing ?? My first video shows why the fuse is blowing and what to fix for that. What make and model convection oven are you trying to diagnose? Quote Link to comment Share on other sites More sharing options...
