Matt NY Posted August 19, 2020 Report Share Posted August 19, 2020 Hi. My grey tank has a crack in the ribs at the bottom. I used Eternabond tape on it but it is just dripping out the ends of the taped area. Since its not a flat surface, eternabond is hard to press into place. Any ideas? Thanks in advance. Matt Quote Link to comment Share on other sites More sharing options...
Ed ke6bnl Posted August 19, 2020 Report Share Posted August 19, 2020 Plastic weld Quote 2000 National RV Sea Breeze 5th wheel 30ft. So.California 1950 F1 street rod 1949 F1 stock V8 flathead 1948 F6 350 chevy/rest stock, no dump bed shortened frame. 1953 chevy 3100 AD for 85 S10 frame 1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc 1970 Baha Bug wihg 2332cc, King coil overs and everything else there is. 1998.5 Dodge 2500 4x4 Cummins, turbo, trans, injectors, lockers, bigger turbo,edge EZ upgrades for towing 35" BFG's, air dog lift pump etc. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 19, 2020 Report Share Posted August 19, 2020 Yup, weld it or replace it. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Ray,IN Posted August 21, 2020 Report Share Posted August 21, 2020 As I said on irv2.com, use a plastic welder, JB Weld for plastic states it is only for rigid plastic, not for anything that will flex. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
