Slixter Posted June 15, 2020 Report Share Posted June 15, 2020 I’ve got a line on a 2012 TSLB with the 3rd air bag. Does anyone have any input on this? How does it compare to the newer TSLB2H? What are the capacities for it?Thanks in advance. Quote Link to comment Share on other sites More sharing options...
rdickinson Posted June 17, 2020 Report Share Posted June 17, 2020 I have a Trailersaver, forgot what model it is. Best to call Trailersave and speak to Aaron. He is or was one of the bosses. The main problem from my standpoint is there is no lubrication points on the main shaft that runs crosswise. So the pin wears the hole into an oblong so you get 'piston slap'. So to speak. I'd check it out first or have someone check it for you. You can try to shoot some lube in and under the jaws. I've had 3 or 4 of them in 15 yrs with different trucks. There may be a way of drilling in for a couple of grease fittings. There is another post running currently at this time which I brought up that question. Quote Link to comment Share on other sites More sharing options...
Slixter Posted June 17, 2020 Author Report Share Posted June 17, 2020 Thanks for the input. I’ll look for that other post. Quote Link to comment Share on other sites More sharing options...
