jcussen Posted June 13, 2020 Report Share Posted June 13, 2020 12 hours ago, GlennWest said: Ours are 58v though at full charge. 12v don't help us Don't know what Sehc is looking at, but If he is considering a 12 volt lithium system like the majority do, the dc to dc charger I recommended will work fine, I use one on my coach which is 12 volt lithium. Quote Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
Sehc Posted June 13, 2020 Report Share Posted June 13, 2020 I am just giving Glenn something to look at. My system is designed and in the build stage. I am using 12 volts as I don't need the power that others use. Sterling has quality equipment. Also Victon has 12/24 volt stuff that is designed to play together. Not for Glenn Quote Link to comment Share on other sites More sharing options...
GlennWest Posted June 13, 2020 Author Report Share Posted June 13, 2020 Schauer makes a nice charger. And if these I getting don't hold up, I likely call them. But what I was getting at Volteq makes some quality power supplies. If one already has solar controlling their charging, just buy one of these and feed that controller. They have one that produce 100v at 20 amp. That 2000 watts feeding a controller. Also most buy over sized solar controller anyway. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
