Wood Deck Build
Brad NSW
Deck will be 10' x 8’-3” wide.
First picture shows 4”x 8” beams attached to the rails, using six LONG U-bolts on each frame rail.  Beams go 3 coats of used diesel oil.
Next the 8ft cross beams (4”x6”) got their preservation coats. 6" side will be up.  They got 3 coats of diesel oil on sides and bottom.  Tops got 4 coats of WATCO Danish wood oil in Dark Walnut.
Next 6” x 3/8" galvanized  lag bolts attached the beams to the longitudinal beam.
70 percent complete.  I will put two 10' 2x6" fascia boards to tie the ends together.  Then I'll screw in a 2 x 10' steel L beam underneath to add more longitudinal strength and help distribute point loads through the deck. Finally I'll attach some nice tie-down D-rings, flush with the deck to hold the Smart Car.
2010 Freightliner, DD15 Eaton Ultrashift, 2015 New Horizons 5th Wheel.
Occupants - Dena/Brad/Hershey    BLOG LINK
Hi Brad,
Thank you for posting your pictures and writing up of what you did. You built one hell of on deck. That deck could hold a bulldozer if needed.
Keep up the good work and please keep posting more pictures,
Al
Giraffe G4.
