Kevin H Posted November 25, 2016 Report Share Posted November 25, 2016 I have a four-step Kwikee/Lippert step setup on our 2013 Montana. So far two of the rivets that are pivot points have failed. One on the right, and today, one on the left. I easily drilled out the hole and put in an grade 8 bolt when the right side broke a couple years ago. Probably will do it again for the left. Also, a rivet that holds on the step plate to the support brace broke. Haven't fixed that yet - thinking about having the plate welded to the braces. Anyway, anyone having the same issues? I thought there was a step recall but I don't remember what the recall issue was. Anyone know if these rivet issues were the recall? How long is the warranty on this item (try to keep a straight face when you spit out 'WARRANTY!!!!?????) Link to comment Share on other sites More sharing options...
Ronbo Posted November 25, 2016 Report Share Posted November 25, 2016 They were recalled and they are just replacing the rivets with bolts. Same thing you are doing. Link to comment Share on other sites More sharing options...
Ray,IN Posted November 27, 2016 Report Share Posted November 27, 2016 The only step recall I have found is for electric steps.https://www.automd.com/recall/lippert_m/ Link to comment Share on other sites More sharing options...
Ronbo Posted November 28, 2016 Report Share Posted November 28, 2016 Here is a recall notice. Although this is for lifestyle there is also one for forest river that I know of. I would also expect it to include all manufacturers that use a lippert frame. http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM481791/RCMN-15V377-1214.pdf Link to comment Share on other sites More sharing options...
Ray,IN Posted November 28, 2016 Report Share Posted November 28, 2016 Looks like Kevin H performed the recall himself. He did what the recall describes and pictures. Link to comment Share on other sites More sharing options...
louielab Posted November 28, 2016 Report Share Posted November 28, 2016 Had to same problem it just gets worse and worse.Throw them in the garbage buy a new set from mor/ryde $348 dollars free shipping online at tweets RV. They will only get worse get rid of them before you get hurt the new mor/ryde safer stair, works great took about 20 minutes to install. They go all the way to the ground with adjustable legs. Link to comment Share on other sites More sharing options...
