jhegdal Posted November 14, 2016 Report Share Posted November 14, 2016 First, I want to be sure that I identify my refrig properly. It seems the Dometic has not assigned a model. It might be NDR1292, Maybe New Dimensions. In any case it is an ammonia absorption system operating on both LP and 120 VAC. Recently, I have been in colder climates where the temperature at night dips below 40 degrees F. The check light goes on and I am unable to resolve that by turning off and on the system. I have tried both the LAC (Low ambient condition) and CLC (Climate control) buttons but neither resolves the check light issue. Strangely, however, the temperature in the refrigerator section is maintained during the night (well within the green section on my thermometer). In the morning with an increase in temperature, I can restart the refrigerator and the check light goes out. So, there appears to be no health problems. My question is this: Is this normal? Or, should have it checked out by an RV technician (My experience with these so-called experts has been dubious at times). Thanks in advance. John Link to comment Share on other sites More sharing options...
Kirk W Posted November 14, 2016 Report Share Posted November 14, 2016 First of all, let me welcome you to the Escapee forums. We enjoy helping our RV neighbors so feel free to join in at any time. My question is this: Is this normal? Or, should have it checked out by an RV technician (My experience with these so-called experts has been dubious at times). No, the check light is not a normal thing and if you are not comfortable trouble shooting, I suggest getting one of the mobile RV techs in your area to check it out for you. If you do not have one, you can get a manual for your refrigerator at the Dometic website. If you wish to do some trouble shooting, you can probably find a service manual at the site of Bryant RV Service. If you look inside of the chill box area or inside of the rear access panel you should find a data plate that will have the actual model listed as well as the serial number. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
D&J Posted November 14, 2016 Report Share Posted November 14, 2016 The check light is for the LP part only,it's telling you the burner didn't ignite. If it works when it warms up check to make sure you have enough propane first. It should work normally on electric even if the propane fails. Denny Denny & Jami SKP#90175 Most Timing with Mac our Scottie, RIP Jasper our Westie 2013 F350 SC DRW 6.2 V8 4.30 Gears 2003 HH Premier 35FKTG Home Base Nebraska Link to comment Share on other sites More sharing options...
Snufy1 Posted November 15, 2016 Report Share Posted November 15, 2016 How old is it some are on recall mine was and I would not have know it if not for the Forum. Like Kirk said get the actual model and serial number and give Dometic a call Tom & Michele 1983 Revcon King33 1989 Goldwing Link to comment Share on other sites More sharing options...
