snowboat Posted August 16, 2016 Report Share Posted August 16, 2016 Does any one have a similar year Travel Supreme? My fresh water fill and kitchen are in the rear. Any idea where the drains are? Winter is coming. Thank you. Link to comment Share on other sites More sharing options...
Kirk W Posted August 16, 2016 Report Share Posted August 16, 2016 Do you mean the low point drains for your water lines? You should be able to see them where they protrude under the RV. Here are some ideas of what they may look like when you do spot them. They may not be red/blue but and might be the same color, but they will project below the floor. They may have caps or there may be valves up above, inside of the heated spaces. There are probably more than one set and there should also be a fresh water tank drain, located near the tank. Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted August 17, 2016 Report Share Posted August 17, 2016 2006 will be white PVC valves sticking through the belly pan. Link to comment Share on other sites More sharing options...
snowboat Posted August 18, 2016 Author Report Share Posted August 18, 2016 Thank you very much. I'll look when I get back home. Link to comment Share on other sites More sharing options...
