dkgood Posted June 15, 2016 Report Share Posted June 15, 2016 The floor of my bedroom slide has severe damage to the floor due to water. Has anyone out there repaired this themselves? Could use input on this problem. Thanks Link to comment Share on other sites More sharing options...
GlennWest Posted June 15, 2016 Report Share Posted June 15, 2016 Slide needs to come out. Feel up to that? Can pull trim off and put 4×4's screwed to sides for support, disconnect rams, remove trim inside and move out to clear. Knock floor out, cut one to fit. Install. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rdickinson Posted June 16, 2016 Report Share Posted June 16, 2016 Is the whole floor ruined, rotten or just some part of it and which part. I re did a large section of mine last year. Slideout did not come all the way out....forklift required for that. Link to comment Share on other sites More sharing options...
