ANG0225 Posted May 31, 2016 Report Share Posted May 31, 2016 One of my extendables does not work. The motor runs and the other extendable works fine. It seems like it has slipped off it's gear or something. Any help troubleshooting and fixing? Had a pretty good trip from Clarksville TN to Kearney NE other than that. The RV Park here is great! Nice lake, free fishing!!. Link to comment Share on other sites More sharing options...
Kirk W Posted May 31, 2016 Report Share Posted May 31, 2016 The first thing that I'd check is for a shearpin as most motor driven slides have one. If you can see the drive systen, just follow it to the point that movement stops and you will find it. Is your slide one that uses a rack and pinion type drive? Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
ANG0225 Posted May 31, 2016 Author Report Share Posted May 31, 2016 Kirk, I think it is Rack and Pinion! Thanks as always Link to comment Share on other sites More sharing options...
Kirk W Posted May 31, 2016 Report Share Posted May 31, 2016 Try and find a place where you can see the rack while someone tries to move the slide. That way you should be able to tell if it is jumping teeth or if no drive is reaching the pinion gear. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Devilishjim Posted May 31, 2016 Report Share Posted May 31, 2016 pinions got a sheared pin 1/4" x ! 1/2" grade 5 bolt should fix you up Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
rdickinson Posted May 31, 2016 Report Share Posted May 31, 2016 Can you post a pic of the motor? If the motor runs but the output shaft doesn't, then it is something inside the motor. Are you able to remove the motor.. I've been thru this several times. Roger Link to comment Share on other sites More sharing options...
ANG0225 Posted June 3, 2016 Author Report Share Posted June 3, 2016 Turns out that the gears are bad inside. Will need to change out the entire leg. I have a guy trying to locate one for me. However, Coachmen is being very slow to respond. Until I get this fixed, how can I brace up my 5th wheel for camping? Right now I have a floor jack under the leg. I guess that is about as good as anything. Is there a better way? Link to comment Share on other sites More sharing options...
Kirk W Posted June 3, 2016 Report Share Posted June 3, 2016 For your front landing legs on a fifth wheel you should be able to use a hydraulic jack under it, but be sure that operating the one that is working don't do further damage to the system. I would jack it up and then put blocks under it for safety in case the jack should collapse. If you are referring to leveling system legs, that should still work. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Devilishjim Posted June 3, 2016 Report Share Posted June 3, 2016 If the front legs are like mine you can just replace the gears it's very simple to do, but that cross shaft that goes from one gear box to the other side also has shear bolts in it at each end.What caused it for me was when I raised the gear up I didnt stop soon enough which bottomed out my gears and something had to give. Its a ring and pinion setup with a thrust washer right above the gear and a pin that goes through the shaft to hold the gear in place. but what happens is if things get in a bind the gear pushes that thrust washer right into that pin So once you get that leg out take the top end apart and I think all you will need is to replace that thrust washer and the bent pin. AND use a vise grip or equivalent and turn that shaft in the right direction to screw it back out a ways. Also mark your landing gear so you can stop raising it before it bottoms out. When you install the leg stick a phillips screwdriver in the hole and crank it down level with the other jack and then install crossover shaft Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
