Just Don Posted March 15, 2016 Report Share Posted March 15, 2016 Cameo Carriage 37cksls: Quadra Rv Bigfoot leveling is popping.Mostly during the heat of the day into the evening and some in am.Some times it's caused by movement most times it's not.Also it's been acting up far as leveling.I have contacted the company they haven't contacted me.Summer of 2015 I stopped by there factory. Very helpfulall they did was reprogram past years they have sent methe electronic leveling instruments(the name slips me).I have checked level of camper most of the time it's low in the frontwith more lower to front driver side some times it's level and controlpanel says it's not I have reprogrammed it no help.After all that back jackets pop more than front does it some.We are mostly in the living room when where home maybe front pops more.I have some wooden blocks under feet heard this helped think I need the thicker more like 4 inch wood blocks.Thanks for your help. Don Link to comment Share on other sites More sharing options...
Big Greg Posted March 15, 2016 Report Share Posted March 15, 2016 Two year ago one of our rear BF would make the same sound, like a circuit breaker blowing. Usually in the afternoons and varied how often it happened. I talked with Quadra and they said they didn't know why. After moving a couple times the problems went away. I believe it was just the one leveler. The noise worried me but there was no other problem. Greg Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted March 15, 2016 Report Share Posted March 15, 2016 A couple of years ago, we had the popping with one of the Big Foot jacks. It went away after we recycled the jacks. No explanation. Link to comment Share on other sites More sharing options...
dswhite Posted March 15, 2016 Report Share Posted March 15, 2016 We have had the popping noise from our Lippert Hydraulic auto levelers. Lippert told us it was from air in the lines expanding and contracting with temperature changes. They had us remove a quart of the hydraulic fluid and replace it with a quart of motorcycle fork oil. It took awhile for the new fluid to work it's way thru the system. The popping slowly decreased and eventually stopped after many cycles. Link to comment Share on other sites More sharing options...
Jim Gell Posted March 15, 2016 Report Share Posted March 15, 2016 For what it's worth, let me add our experience from when we arrived where we are now... We unhitched our trailer from the truck and I started our BigFoot system auto-leveling. While it was was going through it's routine of grounding the jacks and then leveling the trailer, I started hooking up the utilities. All of a sudden I heard a pop noise as the trailer lurched sideways. The BigFoot stopped and display said something about an error and a jack was over extended. One of the front jack pads had punched a hole that looked to be 4-6 inches deep in the sandy soil here at Rainbow Plantation. I raised the jack, put some 2X6's over the hole and leveled the trailer. It seems like it would take a lot of force to punch a hole in the ground like that. I was told by Rainbow Plantation staff that there are no sewer or drainage pipes or anything like that that may have collapsed in that location. To this day, I have no idea what happened. We have a 6 point system that was installed in May 2014. Jim Link to comment Share on other sites More sharing options...
