wlw41 Posted December 29, 2015 Report Share Posted December 29, 2015 Our Fleetwood Expedition is approaching 10 years old which we purchased new. During that time I have never had a thorough inspection of the tank and plumbing. It is not something that would even be looked at in a Pennsylvania vehicle inspection. It seems that I've heard that whoever would make such an inspection must be "certified" but not sure by whom. Would be interested to hear from those that have had their propane systems checked for safety and integrity. Link to comment Share on other sites More sharing options...
Dennis M Posted December 29, 2015 Report Share Posted December 29, 2015 I've had mine checked by my regular RV dealer. Not sure what they do, but I know it includes a leak-down check of the system. Link to comment Share on other sites More sharing options...
Jack Mayer Posted December 29, 2015 Report Share Posted December 29, 2015 Generally if you just do a leakdown check and a physical check of the connections that is sufficient. You may want to see if it has a low-point liquid trap and drain that if present. That is usually somewhere close to the tank - where the iron pipe or copper pipe runs start. The rest of the integrity of the system is really the appliances. And if they are working properly there should be no issues even at that age. But yearly inspection and maintenance of propane appliances is a good habit - follow the appliance manuf. instructions. Link to comment Share on other sites More sharing options...
Kirk W Posted December 30, 2015 Report Share Posted December 30, 2015 . It seems that I've heard that whoever would make such an inspection must be "certified" but not sure by whom. Would be interested to hear from those that have had their propane systems checked for safety and integrity. Do you mean that for some reason you feel the need to get it inspected? The type of propane tank that is permanently installed in vehicles is required to meet ASME standards which are different from those on portable bottles, and the ASME tanks certification does not expire the way that portable bottle DOT certification does. They use a significantly different standard and different rules. Link to comment Share on other sites More sharing options...
wildmandmc Posted December 30, 2015 Report Share Posted December 30, 2015 good question, as i have a 2000 dp. tank is original. here is what i was told by a propane salesman, in ref to my household Grill propane tank, its dated, an he said they not suppose to fill tanks that are over 10 yrs old. Now i realize tank size is much different, are walls made thicker than household grill tanks? Link to comment Share on other sites More sharing options...
Yarome Posted December 30, 2015 Report Share Posted December 30, 2015 if you just do a leakdown check and a physical check of the connections that is sufficient. The type of propane tank that is permanently installed in vehicles is required to meet ASME standards which are different from those on portable bottles, and the ASME tanks certification does not expire the way that portable bottle DOT certification does. They use a significantly different standard and different rules. X2.. Link to comment Share on other sites More sharing options...
Yarome Posted December 30, 2015 Report Share Posted December 30, 2015 Now i realize tank size is much different Not necessarily. There are small ASME tanks.. and they may not always be horizontal. If in doubt, check the rating marks. Capacities will be measured in pounds for a DOT tank while an ASME will be rated in gallons... and yes, the construction standards are quite different. Link to comment Share on other sites More sharing options...
Kirk W Posted December 30, 2015 Report Share Posted December 30, 2015 Must have been too late at night, Yarone......... ASME tanks are tanks that meet the standards set by the American Society of Engineers. That’s where they get their designation of ASME. No retesting period Heavier than DOT tanks of the same size Thicker steel provides longer life Data plate markingsIntended service (AG or UG) Water capacity Design working pressure “This Container Shall Not Contain a Product Having a Vapor Pressure in Excess of __ Psig at 100 degrees F.” Outside surface area Year of Manufacture Serial Number ASME Code Stationary ASME tanks are different than mobile ASME tanks in that they are not designed to be moved when they are legally full of gas. LocationMust set at least 10 feet from external source of ignition, intake to direct vented gas appliance, or intake to a mechanical ventilation system No minimum distance between two tanks 5 foot minimum distance to openings below the top of the tank DOT tanks are governed by a different set of standards. The Department of Transportation sets the standards for the transportation of hazardous chemicals and so the tanks that transport them have to be under strict regulation. DOT Tanks DOT retest periods are 12 years after manufacturing, then each 5 year period thereafter if done visually Portable tanks normally used for Temporary Service at construction sites or for emergency services at a customer’s site Inscribed on the collar of tankDesign code Water capacity Retest date Tare weight Dip tube length Location10 foot minimum from external source of ignition, direct vent, or mechanical ventilation system 3 foot minimum distance to openings below the top of the tank Link to comment Share on other sites More sharing options...
