Shallow Draft Posted December 17, 2015 Report Share Posted December 17, 2015 Hi all Does anyone know the ride height of a Volvo cab? And where it is measured from , the stoppers or the frame. I am changing cab shocks and I will have to remove and likely replace the leveling valve while I am at it. Thanks Link to comment Share on other sites More sharing options...
Darryl&Rita Posted December 17, 2015 Report Share Posted December 17, 2015 Instead of relying on internet help, I'd rip and tear, then use body panel line-up to set the ride height. Stand back, so you can see the bottom edge of the cab/sleeper, and the top edge of the fairings. Adjust as needed. Link to comment Share on other sites More sharing options...
Shallow Draft Posted December 18, 2015 Author Report Share Posted December 18, 2015 Good advice... Seems like a reasonable approach.. Cab shocks are in. Definitely a 2 person job. Cab leveling Valve was leaking bad. Tomorrows Job. All is good in the desert. Link to comment Share on other sites More sharing options...
