rdickinson Posted December 11, 2015 Report Share Posted December 11, 2015 Mine is on the fritz. I seem to recall a post and 2 pics about this. Can anyone recall and send a link. I've tried 'searching forums' using a variety of wording. Thanks Link to comment Share on other sites More sharing options...
Nigel Posted December 11, 2015 Report Share Posted December 11, 2015 Roger I think this is the one you might be looking for. There was another started by RandyA as well about results. http://www.rvnetwork.com/index.php?showtopic=119157&hl= Nigel Link to comment Share on other sites More sharing options...
rdickinson Posted December 11, 2015 Author Report Share Posted December 11, 2015 Thanks, I'd like to check sensor and gauge independently if possible. No sense replacing something that's not broke. HD had a question on how to test it or them but got no answer. So I will ask the same question. Good thing Randy got that before his "incident" which probably still hurts. Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted December 11, 2015 Report Share Posted December 11, 2015 Roger, here is the Youtube video that Big5er sent to me when mine was giving trouble. https://www.youtube.com/watch?v=UiXKrptx4tE. I followed the instructions and changed mine. You will have to cut and paste this because I don't know how to just make a link to it. This makes the change differently than Randy did because he cut the wires from the new sensor and just made splices to the existing wires instead of removing the side panels and replacing the entire unit. Randy is much better at soldering and splicing than I am. The entire replacement only took removing about 7 screws and 3 zip ties so it was not bad at all. I can't tell you how to check the sensor but if you pull the 2 bolts out of the manifold and lift out the sensor your should be able to look at the end of the sensor and see what shape it is in. HOWEVER, you may want to have a new sensor on hand or be able to get one quickly using another mode of transport because mine came out in pieces. Just an FYI. Brad PS: you can find Randys method and explaination in the thread titled Volvo D12 Boost Sensor Replace Short Cut Link to comment Share on other sites More sharing options...
