transmission codes and message
Shallow Draft
Battery issues will do that. Grounds especially, as noted here and elsewhere. It is worth cleaning the battery connections, AND the connections to the starter and any shutoff or fuses you have. My battery isolation switch was pretty groddy and was causing hard starts. Make sure that the buss bar bridging between the batteries is in good shape as well. Not all of this relates to your trans issue, but worth doing yearly (or so). I just did mine because my Batteryminder trickle charger showed "bad battery" and would not complete a full charge (which it always does). A sure indication of a groddy connection OR a bad battery. Cleaning things got it back to a full charge and no faults on the charger.
RV Cable Grip
RV Cable Grip
RV Air.
