EKBendana Posted June 5, 2015 Report Share Posted June 5, 2015 Just wondering if anyone has rustproofed the frame of the rig? I was thinking it may not be a bad idea? Link to comment Share on other sites More sharing options...
skp51443 Posted June 5, 2015 Report Share Posted June 5, 2015 We did some touch-up on our frames over the years, never a full rust-proofing job. What are your rails treated with now and what were you thinking of using as rust-proofing? First rule of computer consulting: Sell a customer a Linux computer and you'll eat for a day. Sell a customer a Windows computer and you'll eat for a lifetime. Link to comment Share on other sites More sharing options...
richfaa Posted June 5, 2015 Report Share Posted June 5, 2015 Most if not all RV frames are powder coated. ...... powder coat is abrasion, corrosion and chemical resistant. This does not mean that it will not crack, peel, chip, scratch, or corrode. It just means that it is more resistant than some other finishes. There has been a misconception that powder coat is crack, chip, peel, abrasion, corrosion, and chemical proof. That is sadly not the case. Powder coating is stronger than paint but given the environment it is subjected to, it can only resist so much. Our Rv has never seen winter or high salt areas and rust on the frame is practically nonexistent.. Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
Kirk W Posted June 5, 2015 Report Share Posted June 5, 2015 On our motorhome that we were full-time in for 11+ years, I did have the entire thing undercoated and that was pretty effective and could be on a trailer too if done well with high quality materials. While that sort of thing does look nice, in all of my years of RV travels, I can't remember ever hearing of a structural problem that was caused by rusting of the RV frame. I'm sure that it might happen if you were in a place where things are exposed to salt air all of or most of the time, but I can't recall hearing of that issue either. I really think that most of us who have done things in the area of frames have done so mostly for cosmetic reasons. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
D&J Posted June 5, 2015 Report Share Posted June 5, 2015 I see by your avatar that you have a 5th wheel, what I did with ours is clean and paint the pin area and any frame that can be seen with Rustolium and the rest I used rubberized black undercoating. We have a white frame so any exposed frame areas showed up rust. Denny Denny & Jami SKP#90175 Most Timing with Mac our Scottie, RIP Jasper our Westie 2013 F350 SC DRW 6.2 V8 4.30 Gears 2003 HH Premier 35FKTG Home Base Nebraska Link to comment Share on other sites More sharing options...
EKBendana Posted June 16, 2015 Author Report Share Posted June 16, 2015 thanks everyone! I think this will be a good do it yourself project! Link to comment Share on other sites More sharing options...
