Frig on the "electric" setting while towing
TxCowboy
Seems a good place to ask this question and, yes, it's probably a no-brainer.
Is the 7 pin electrical connector providing enough power to operate the FW refrigerator on the electric setting while being towed?
Thanks!!
Jeff & Laurie
South Texas
Hounds: Auggie (beer drinking English Cocker Spaniel)
Angus (five pounds of bad azz chihuahua)
Homebase: 2015 Heartland 365 Key West -- The "Uno Mas"
The Office: 2016 Crossroads Hill Country 26RB
Unless you have what is called a "3 way" refrigerator, or possibly an inverter to supply the power, your refrigerator will not cool while driving because the standard RV refrigerators require 12V for control circuits and either propane or 120V-ac for the heat source. Of course, if your RV has a household type refrigerator, and an inverter to change 12V-dc to 120V-ac power to supply it, then it may work. Since it wouldn't be running all of the time, the 12V charging lead in your 7 pin connector probably will keep up with the demand for power.
Nope, it's a two-way. Gas it is and, yeah, I've been reading the on-going thread about using the propane system while towing.
Thanks, Kirk!
Jeff & Laurie
South Texas
The fridge probably needs about 500 watts, 40 amps to run on AC which is a lot to expect from the trailer plug's wiring. It is intermittent as Kirk mentioned so you would likely keep up if you put an inverter in the RV.
Running an inverter in the truck and using two extension cords (so they can unplug if pulled on) is a much better idea and it gives you AC power in the truck for other uses.
I would caution you about inverting AC in the truck and sending it over to the trailer. You need to do that correctly - taking appropriate safety measures - or you can cause a real issue if things go wrong. You need to know what you are doing and use appropriate plugs/receptacles if you tackle sending 120v across. Bill does know what he is doing, so his installation is safe. But this is not something I'd recommend for people not familiar with safety issues with 120v power.
Living on the road since 2000
2022 New Horizons 43' 5er
2016 Itasca 27N 28' motorhome
www.jackdanmayer.com
Thanx Jack - I should have included that. Special waterproof plugs and receptacles, fuse / circuit protection. I also run the trailer charger so there is an automatic 12V disconnect from the 12 V charge line of the truck plug --- circulating currents, 12v on the truck, invert to 120, to the trailer, charge the batteries at 14V, (disconnecting relay inserted here), 14 volts back to the truck through the Bargman plug, charging the truck battery. invert to 120VAC and the circle continues..
You also have to be VERY cognizant of the alternator capabilities of the truck. Most are rated for the SLI batteries in the truck and will not sustain a continuous heavy load.
Bill and Cecil
2007 Volvo 780 Motorhome - Autoshift 3 Trans | 2003 38' New Horizons 5'er
Photobucket Pictures
