Wilkie Posted February 8, 2015 Report Share Posted February 8, 2015 I have just changed exchanged my leaking Atwood water heater with a new Atwood water heater and now I have very low water pressure in all the hot water taps. Any idea what caused this and what is the remedy Link to comment Share on other sites More sharing options...
Kirk W Posted February 8, 2015 Report Share Posted February 8, 2015 Welcome to the Escapee forums! Are you sure that you don't have a bypass valve in the wrong position? Have you opened the relief valve to vent air out of the water heater to be sure that it has filled? It is possible that the check valve is bad, particularly if you didn't use a new one with the installation. It could also be that the new install introduced some sort of debris into the system so try removing the screens from each faucet to be sure that they are clean, although that would impact the cold side also. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Wilkie Posted February 8, 2015 Author Report Share Posted February 8, 2015 What check valve are you talking about, to my knowledge there is no check valve in my system. Link to comment Share on other sites More sharing options...
Kirk W Posted February 8, 2015 Report Share Posted February 8, 2015 Most RV water heater installations have a check valve in the hot water outlet. It usually just looks like a plastic nipple. They may be either brass or plastic. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Wilkie Posted February 8, 2015 Author Report Share Posted February 8, 2015 There is no check valve in my hot water line. In my first message I forgot to mention the pressure in the cold water line is okay, full pressure. Link to comment Share on other sites More sharing options...
kathydavidb Posted February 8, 2015 Report Share Posted February 8, 2015 I'm wondering if you knocked some crud loose during the installation and that crud is partially blocking the hot water line? Dave. 2006 Coachmen Aurora 36ft. Class A motor home. 2009 Honda CRV toad. "Snowbirds" apprx. 6 mos. each year. Travelling to the SW each winter than returning to Wi. each summer. Retired and enjoying our travels along with Buddy the cat. Link to comment Share on other sites More sharing options...
Kirk W Posted February 8, 2015 Report Share Posted February 8, 2015 Do you have a bypass kit on yours? Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
oscarvan Posted February 8, 2015 Report Share Posted February 8, 2015 Although messy, the only way to do this is one step at a time. If it were me I would disconnect the hot water plumbing form the heater, attach a hose and check for pressure....Then work your way down stream until you find it. Yes, make sure there's not a check valve in line somewhere. Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/ Link to comment Share on other sites More sharing options...
Ray,IN Posted February 9, 2015 Report Share Posted February 9, 2015 There is no check valve in my hot water line. In my first message I forgot to mention the pressure in the cold water line is okay, full pressure. Referencing Kirk's photograph, since you said you do not have a check valve in the hot water outlet, you will have a 3rd 1/4 turn valve as part of the bypass kit. That 3rd valve must be open, exactly like the cold water bypass valve. Some installations have a check valve on the cold water inlet, if your does, insure it is installed the correct direction. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
