Adding portable solar to existing
I have a full Bogart system in my travel trailer. Trimetric and chargecontroller with  three 140w panels on the roof. At times I’m camped where panels are shaded. I want to add 100w portable panel that I can better position toward the sun. It comes with its own charge controller. What is the best way to connect this to my existing system?
Attach new controller to battery or run the charge controller through the existing Bogart charge controller?
iwant the trimetric to still monitor the entire system.
Thank
RoyB
South of Boston
2021 Dodge 2500 - 6.4L
Forest River 19RR Toy Hauler
Roofnest Falcon Rooftop Tent
www.rvbprecision.com
Good questions, I've seen several do the same thing you are. For sure you don't need two controllers, so if the portable has its own I've seen many successfully attach the portable panel with its own controller to their battery bank (NOT mess with your in place system). Its like using two hoses instead of one to fill the pool lol. Of course, for a battery monitor to sense and measure all in and all out you wire the potable system negative to the shunt (if you have that type of monitor) where everything else is.
 If you try and connect to mix n match different panels (rooftop plus portable) as I'm sure you already know they would need to be properly matched.
 John T
4 minutes ago, oldjohnt said:
...I've seen many successfully attach the portable panel with its own controller to their battery bank
That's what we do with our portable solar panel (we have one 160-watt solar panel on the roof).  The portable solar panel came with a cable that's attached directly to the battery to which we then attach the portable panel.
LindaH
2014 Winnebago Aspect 27K
2011 Kia Soul
If those 3, 140 watt panels on the roof are wired in parallel ( I assume they are) and if the VoC voltage ratings of those panels and the 100 watt panel are about the same, (around 20-22v) and if the controller will handle the additional amps, then you can simply wire the portable panel in parallel with the existing panels.
A lot of 'ifs'....so it is usually much easier to simply wire in the portable panel with its own controller to the existing bank.
Nothing to see here.
