bigredhdt Posted February 27, 2019 Report Share Posted February 27, 2019 Going to replace steer tires. I have 275/80R22.5 now, but it seems 295/75R22.5 are more common. The 295 is same height, about .8" wider. Any recommendations or advise? Link to comment Share on other sites More sharing options...
ARGO Posted February 27, 2019 Report Share Posted February 27, 2019 I have run both. As long as they match, you're good. I seem to remember that Michelin is the only mfr making 275's or something like that. You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
Phil D Posted February 28, 2019 Report Share Posted February 28, 2019 On 2/27/2019 at 7:11 AM, ARGO said: I seem to remember that Michelin is the only mfr making 275's or something like that. Michelin isn't the only one, but in my experience, there does seem to be a pattern. European manufacturers (Michelin, Continental, etc.) and their second and third tier brands tend to go with the narrower width/taller sidewall sizes, i.e. 275/80R22.5, while North American and Asian manufacturers (Goodyear, Bridgestone, etc.) and their subordinates go with the wider/shorter sidewall variants, like 295/75R22.5. Both are equivalent as far as load capacity, etc. Phil 2002 Teton Royal Aspen 2003 Kenworth T2000 - Cat C12 380/430 1450/1650, FreedomLine, 3.36 - TOTO . . . he's not in Kansas anymore. ET Air Hitch Link to comment Share on other sites More sharing options...
Imurphy907 Posted February 28, 2019 Report Share Posted February 28, 2019 When I worked in the tire industry we treated those two sizes as basically interchangeable. As you said they are the same OD and that is all most people care about. Depending on the type of road conditions you drive on there could be a SLIGHT advantage to the wider tire but most people never cared much. 2016 Road Warrior 420 2001 Volvo VNL 660 Alaska Based. Link to comment Share on other sites More sharing options...
