Major Problem - 2019 Entegra Vision 26x
Our RV has less than 9 inches of clearance in the front. Since we purchased it, we put about 2,000 miles (4,400 total) on it. One day while pulling into the driveway of a RV park, we heard an extremely loud noise, as if the frame of the RV was dragging against the ground. When we looked, we were not high-centered. Instead, the right front wheel was rubbing the inside the wheel-well. In order for us to get into our RV spot, we had to drive extremely slow and back up several times in order to the RV in the proper position. The next day when it was light out, we notice how little of ground clearance we have in the front. Additionally, when looking at the wheel well on both the drive and passager front, the wheel well sits lower than the top of the tire.
No one has been able to identify the problem yet. It has been very challenging to get help with this issue
There is something seriously wrong with our RV (probably suspension)
ANYONE ELSE OWN A 2019 Entegra Vision 26X? Please contact me if you are experiencing the same issue?
I agree, have  the front ride height valve inspected, it may be un-attached. The  setting is critical for several reasons.
Whoops, thanks for catching that jcussen. That's what I get for speed reading. Sorry Nick, forget my reply it does not apply.
4 hours ago, jcussen said:
Believe you have the F53 chassis
You are so right! I guess I had not realized that Entegra even made a gas chassis coach. That does mean that the problem is not airbags. In fact, the Entegra Vision 26X only has a 16,000# chassis also. That pretty much says that the problem is not airbags, as I had predicted. Do the front springs look normal or might they be collapsed?
Over the years I have know of broken rear leaf springs on pickup trucks from overloading and age, but on a new gas motorhome I would guess that is rare.  However, not sure on the F53 suspension what else it could be.  The only other thing that comes to mind is if someone tinkered around and did the CHF (cheap handling fix) and either didn't get a bolt tightened or did something else wrong.
Joe & Cindy
Newmar 4369 Ventana
Pulling 24' enclosed (Mini Cooper, Harley, 2 Kayaks)
