Converter as Charger
dewilso
Don't know, but did use my smart rv charger converter to charge my trolling motor for my few week fishing trip and worked fine
2000 National RV Sea Breeze 5th wheel 30ft.
So.California
1950 F1 street rod
1949 F1 stock V8 flathead
1948 F6 350 chevy/rest stock, no dump bed shortened frame.
1953 chevy 3100 AD for 85 S10 frame
1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc
1970 Baha Bug wihg 2332cc, King coil overs and everything else there is.
1998.5 Dodge 2500 4x4 Cummins, turbo, trans, injectors, lockers, bigger turbo,edge EZ upgrades for towing 35" BFG's, air dog lift pump etc.
While I am not a fan of WFCO products, I see no reason why this should not work reasonably well. It won't do all of the things that a good battery charger will, but it will charge a battery and should serve well enough for intermittent use like would be the case in most shops. My primary issues were of longevity and reliability and those should be much less issue in your kind of use.  The WFCO website says that you do have 3 stage charging ability.
Dewilso, I don't forsee any big problem using it as a "shop battery charger". After all its designed to take 120 VAC and charge/maintain a 12 VDC battery or supply loads RIGHT ???
 HOWEVER in the event its a "dumb" non multi stage "smart" charger I would be hesitant to stick it on a battery and leave it unattended for hours on end as it could over charge a battery. Some of the early charger/converters were more of a fixed voltage power supply and could harm a battery if left on too long.    I have an old one at home Ive used to charge batteries and it "worked" but it didn't have any regulation whatsoever.
Good luck n best wishes
John T  Live dry camped in Magnolia Beach Texas headed to Matagorda Bay
I believe he is referring to a good multistage charger, I used a Progressive Dynamics with a wizard works great.
So.California
1950 F1 street rod
