hiljoball Posted July 31, 2018 Report Share Posted July 31, 2018 I have a Garmin nuvi 2689LMT and it connects to my old laptop via USB with no problems - but time to retire that laptop. I bought a new HP 15 inch laptop with 2 USB3 and 1 USB2 ports. The Garmin will not connect - The Garmin comes up with e message that it cannot charge and to use the supplied Garmin cable. - but that is what I am using. I also tried several other USB cables all with the same problem. Unless the Garmin is detected (and mounted as an external storage device) I cannot access it with Garmin Express to update it. To summarise - the Garmin connects to my old laptop (USB2 only), but will not connect to any ports on the new one. Other devices, such as a thumb drive, External hard drive and USB headset all connect to the USB on the new laptop. Garmin support says it is a HP problem. HP support says that if other devices work on the USB ports, it is not their issue. Help!!! Thanks John JohnTitanium 29EX 29/34 Fifthwheel Link to comment Share on other sites More sharing options...
mike54 Posted July 31, 2018 Report Share Posted July 31, 2018 I had that problem with my Rand McNally gps it took about a year calling Dell and Rand McNally but I finally got a tech at Rand McNally who knew what the problem was took remote access and fixed the problem. it was a setting he knew about that fixed it. Mike 2007 Montana 3500rl 2005 Dodge Ram 3500 CTD Link to comment Share on other sites More sharing options...
mptjelgin Posted July 31, 2018 Report Share Posted July 31, 2018 For some reason I've found my Garmin GPS(s) particularly sensitive to the specific USB cable that I use. Many of my cables won't "connect". Do you have a couple of different cables you can try? Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
hiljoball Posted July 31, 2018 Author Report Share Posted July 31, 2018 as noted in my OP, I tried several cables. No improvement. One suggestion on the POI factory is a voltage problem - late model GPS need more power, and newer laptops USB ports are lower than previous. So one suggested solution was to buy a powered USB hub. Yet Garmin says not to use a hub. Don't want to spend money if it will not solve the problem. To Mike54 - do you know what the Tech changed? John JohnTitanium 29EX 29/34 Fifthwheel Link to comment Share on other sites More sharing options...
hiljoball Posted August 1, 2018 Author Report Share Posted August 1, 2018 Here is an update on my Nuvi to HP USB problem. I took my GPS into Bestbuy, where I bought the laptop and did an experiment (with the store's permission). I plugged the GPS into an identical model HP laptop and it also failed. Then plugged it into three late model but different HP laptops. It failed in each one. Then I plugged the GPS into an Acer, Dell, and Levono late model laptops and it worked in each case. So my conclusion is that there is an issue in the USB device manager on the current HP laptops that I tested. I'll report to Garmin and to HP to see what happens next. John JohnTitanium 29EX 29/34 Fifthwheel Link to comment Share on other sites More sharing options...
