Dennis M Posted October 23, 2017 Report Share Posted October 23, 2017 My air is leaking down fairly quickly, going to take it in for an overall check shortly, but when I shut down I can hear what sounds like a high volume, low pressure air leak in the area of the compressor. More of a 'whoosh' than a 'hiss' sound. Maybe internal leakage in the compressor? Which produces three questions: can the air compressor be rebuilt? Is there a rebuild kit? And, if so, can a reasonably competent mechanic do it himself? I was ASE certified Master on cars many moons ago, but HDTs are a completely different animal! Dennis & NancyTucson, AZ in winter, on the road in summer.1999 Volvo 610 "Bud" 425 HP Volvo, Super 10 spd.2005 Mountain Aire 35 BLKS2013 smart fortwo CityFlame riding on Bud(Replaced '05 smart first loaded in '06 and '11 smart that gave it's life to save me!)Our Travel Blog Link to comment Share on other sites More sharing options...
NoDirectionHome Posted October 23, 2017 Report Share Posted October 23, 2017 sounds like you lost a reed or unloader is hanging open. Kits are cheap & easy. http://www.bendix.com/media/documents/products_1/compressorsgovernors_1/ba921servicedatasheet.pdf "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
RandyA Posted October 24, 2017 Report Share Posted October 24, 2017 3 hours ago, Dennis M said: Which produces three questions: can the air compressor be rebuilt? Is there a rebuild kit? And, if so, can a reasonably competent mechanic do it himself? I was ASE certified Master on cars many moons ago, but HDTs are a completely different animal! Naw - you just need a bigger hammer and wrench than you do with a car. I replaced my compressor a couple of years ago by myself. I did not have time to do a rebuild but getting it off is not difficult. You will need to drain and capture coolant. Not sure on your engine but I needed new compressor coolant hoses and "O" rings when I put the new one on. Also, the compressor is heavy - I had trouble getting it back into position by myself. A second strong arm would have been appreciated for that part. With time to get the right rebuild parts and having a big workbench in a clean area, I would not hesitate to undertake an overhaul. With your background as an ASE Master your KSA's are better than mine so you should be fine. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
dennisvr Posted October 24, 2017 Report Share Posted October 24, 2017 If my memory serves me right, I believe you should have a one way check valve between the compressor and the wet tank. If it is working correctly the air should not be able to bleed back to the compressor. "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
