trimster Posted June 8, 2023 Report Share Posted June 8, 2023 Not sure what to call it, other than the plate on the firewall that a lot of airlines go into and through. Drivers side. I've replaced the o-rings and some lines, but one will not stop leaking no matter what I do. I'm thinking that this junction place needs to be replaced. Not uncommon for Volvos. Apparently, other brands have brass replaceable line connections... not Volvo. Bummer Any help with how to attack this fix would be appreciated. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Parrformance Posted June 8, 2023 Report Share Posted June 8, 2023 It was an easy project, I took multiple photo’s drew a very detailed map, then tackled it. Surprisingly easy job. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
trimster Posted June 8, 2023 Author Report Share Posted June 8, 2023 Is it all from the firewall side? Or do I have to pull the under part of the dash appart? Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Parrformance Posted June 8, 2023 Report Share Posted June 8, 2023 Work is from both sides, I recall drawing a detailed map of both sides. Then labeling things with masking tape, next step was removal. The under dash things on my 06 were not extensive as I recall. While your in the vicinity, there are some ground lugs just above the pass through under the hood, that should be inspected and cleaned as necessary. I was very apprehensive before I got started. I made quite sure I had everything written down, inspected, photographed, and memorized. The job itself after I did that much preparation was relatively simple. Just take good notes and photos, work patiently, and you can do it. Michael Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 8, 2023 Report Share Posted June 8, 2023 Did it also several years ago. As Michael said, wasn’t that difficult that I recall and all my friends will tell you I’m not very mechanical. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
