Lowell Posted May 28 Report Share Posted May 28 I have a 2007 Teton Royal that has a 4 point level system with a ground control On a tethered control box. It has rocker switches for front and rear left and right and extend and retract. Made by Lippert. The jacks are hydraulic Can not find any info on this Can you help The. Lippert website only deals with the new auto level stuff Lowell Quote Link to comment Share on other sites More sharing options...
j2catfish Posted May 30 Report Share Posted May 30 What info are you looking for? I have a 2007 Teton Experience with the same system. I usually use the front or rear switches together to raise/lower the jacks. If the unit is not level I select the single switch that will level it. The individual jacks are not powerful enough to raise the entire area off the ground as some motor homes are said to do (to change a tire, etc). Hope this helps some. Catfish Quote Link to comment Share on other sites More sharing options...
rpsinc Posted May 30 Report Share Posted May 30 3 hours ago, j2catfish said: What info are you looking for? I have a 2007 Teton Experience with the same system. I have an '08 Experience. What do you want to know?? Quote Link to comment Share on other sites More sharing options...
